i got a question it might sound stupid.
my dads got the new grange and what i really like about it is its gear knob.
and i wanted to know if its possible to put this in my VS. if it is possible can you guys give me a rough idea of what has to be done.
it can be done but i do warn that it is very hard, because its involes a fair amount of work to get it to sit right an i can't promise that i'll line up with the gear display. i do know a guy from another forum has done it as well an his lines up pretty well.
any more info you need i'll try an help
if you could please get info that would be great !!![]()
thnx
here goes, these are only a couple of my notes
1- you will need the complet shifter. i mean the handle an the base
2- the linkage between the trans to the shifter may need 2 be extended
3- thin sheet of some sort of flexible metal for the hole
4- on the bottom half of the shifter the arm will need to be bent to fit over the trans as the vs is more off set then the vt-vz
5- the inhibater swicth will to be transfer onto the new shifter, it may take time to get it line up right
6-the base of the shifter might need some modification done to fit under the cover i.e some bits will need to be cut away
sadley thats the best i can do right know untill i start reworking on it again.
an another thing is the gear select display might need to be glued to the cover as they are different from the vt etc.
as i said before its involes a bit of work an i only done it pretty rough, but as soon as i get around to finishing it, i'll try offer more help as i go
