Results 1 to 5 of 5
Thread: getting to the arial motor
    System's Avatar
    System is offline Control is a way of life
    2005 VZ commodore exec
    Oct 2007
    Default getting to the arial motor
    hey all i have a 93 VR acclaim and it has a motorised arial. Now the problem is that a month ago the arial broke- so i just pulled the whole lot out, including the knotched rod thing that sits inside to push it up.
    BUT now every time i start/turn off, the motor still wirs away and sounds awful lol. I wanna get to the motor and unplug it (i plan to get a new NON motorised one later), to i can have peace and quiet, but i dont know how to get the dash off :P
    me and a m8 tried b4 but we just found another wall of plastic and more cables... this is behind the glove box btw.
    even if there is a link to a DIY thread could someone post pls?
    cheers.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Im not 100% sure what our saying there, but if your after the actual motor its under the wheel arch, you have to take the plastic out from above the front wheel, its only a few screws, its easiest to take the front wheel off, but not completely nessacary, if you turn the wheel out.
    Reaper
    System's Avatar
    Oct 2007
    aaah rly? i thought i had to go through the dash to get to the arial. ok i'll give it a shot tomorrow and let ya know
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You can get replacement motorised ones from Supercheap for around $80 or so. Installation takes a bit of fiddling to get the brackets right and get the aerial vertical.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, not sure if you've got this fixed by now, but I changed my aerial by reaching in through the wheel arch plastic. Easy to get to if you have the wheel turned the right way
    The 1972 HQ Kingswood
  1. How to change the arial?
    By Big_Lebowski in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2009, 07:42 PM
  2. VP Arial? Stays up?
    By benjiaka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2007, 01:36 PM
  3. VN Electric Arial keeps going down
    By 88GreenVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-07-2006, 08:43 PM
  4. install an arial
    By Duck_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2005, 10:59 AM
  5. VQ arial
    By yotaman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2005, 04:29 PM
