Results 1 to 20 of 20
Thread: rockers for my vs
    vp berlina lx
    Jan 2008
    melbourne vic
    Default rockers for my vs
    i read a DIY article in street commodores today about changing the rockers on a ecotec from the standard 1.65:1 to 1.9:1. it looks quite simple to do but is it worth doing and will it be a significant gain and is there anything else that needs to be done before/after you do this
    vp berlina lx
    Jan 2008
    melbourne vic
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    patience grasshopper!
    what else did the article say about doin the mod? during the 1.5hrs waiting for a response, did u have a quick search? V6 mod & development section is a good place to check
    Yes its easy if you have a lil knowledge with spanners, and its an awesome mod and a definate bang for your buck!
    VZ SS 6 SPEED MANUAL
    Apr 2007
    WA
    Hey man
    There good to get mate, though you wont get the best benefit out of them with out extractors, exaust and CAI.
    Apr 2007
    WA
    vp berlina lx
    Jan 2008
    melbourne vic
    well ive already got the extractors and exhaust and cai fitted but i wanted to kno if there was anything else i had to do in order for it to be at full effect and running smooth so to speak
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    u've got all the goodies just add ur rockers and ur set to go
    Apr 2007
    WA
    Quote Originally Posted by ephect View Post
    Yeah mate, i agree......
    vp berlina lx
    Jan 2008
    melbourne vic
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    hard really to say exactly but prolly 5-20rwkw with the combo
    2x VS
    Jul 2005
    I've seen it written on other sites that rocker ratios higher than 1.8:1 require upgraded valve springs to prevent valve bounce. Best to ask this question again in the Yella Terra section or search their area of the forum.
    Disclaimer For The Reader ::
    The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
    If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
    or do not use the information at all
    I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
    I am NOT a Mechanic. You have been warned.
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    2x VS
    Jul 2005
    I'm not really sure what other N/A eco-tec options there are.
    Cursed CX8 is offline Banned
    VY Adventra
    Feb 2008
    Walking distance to FG meets
    there are also MACE and FIT rockers, BUT they are just 're-manufactured' rockers, not a rocker will roller tip as well as roller mount
  15. #15
    vp berlina lx
    Jan 2008
    melbourne vic
    Quote Originally Posted by sixshooter View Post
    if this is so what sort of valve springs would i need to get, ones to suit the high ratio rocker i assume are they hard to fit?
  16. #16
    VY Adventra
    Feb 2008
    just an upgraded spring my crow etc, speak to the dealer that you get the rockers from to see what they recommend. The springs are the harder part of doing the rockers because they are fiddly as hell to remove.. well thats what i found anyways
  17. #17
    VS III S/C 50th Statesman
    Apr 2008
    I have the 1.98's from MACE on my car. 1hr to fit and about 3hrs to access and repaint the valve covers!
    They do appear identical to the stockers but how are they remanufactured to be different? I didn't compare them closely at the time but do they have more movement in the rocker itself or is the pad or pushrod location modified for more lift? Is it the valve covers themselves that limit the rocker ratio in this instance or just the limit for how the original style rocker can be modified?
    cheers
  18. #18
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    they reweld where the valve rests on the tip, then grind to the required lift.
    i have the FIT 1.9s, and love em
  19. #19
    VY Adventra
    Feb 2008
    Quote Originally Posted by Aus78Formula View Post
    cheers
    how did you find the performance of the 1.98's? I was looking at getting a set but what to know what people think
  20. #20
    Apr 2008
    Thanks, I thought they looked thicker in that area but the originals were all oily so couldnt compare and had to get on with the job!
    It's early days, only driven the car on a few short trips since and nothing overwhelming with power but does feel more torquey, pulls away more smoothly but doesnt appear to sound very different to what you'd expect from a cam change or similar. I still have smaller pulley and larger intake throttle body to fit so hopefully they will compliment each other rather than just expecting one mod to change the whole car.
  1. Rockers for a '92 VP V6
    By Cobez in forum Yella Terra
    Last Post: 27-08-2008, 11:57 AM
  2. Rockers for VN 5.0
    By AirStrike in forum Yella Terra
    Last Post: 05-02-2007, 03:48 PM
  3. VP Rockers
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2007, 04:16 PM
  4. Fit Rockers
    By droidt in forum V6 Development And Modification
    Last Post: 17-09-2005, 12:37 PM
