muzza
- Aug 3, 2005
- 306
- 0
- 0
- Age
- 50
- Location
- gladstone
- vx berlina
hi guys i own a 97 vs v6 sedan with standard brakes i was just out changing the pads as ive done a few times but this time when i pushed the piston in popped the new pads in the caliper and went to bolt it back up to the caliper mounts it wont fit on its like the peice of the caliper that sits in place with the 2 guided pin things isnt out or in far enough as a peice of the caliper hits on the disc when i go to line up the 2 bolt holes also from memory the 2 pieces of the brake caliper should slide a bit mine is like siezed or sumthin which might xplain why the pad wore prematuley and gauged the old rotor a bit anyway is annoying any help would b good thanks
