Results 1 to 10 of 10
Thread: Battery light & Check Engine light
    VS S2
    Aug 2008
    Default Battery light & Check Engine light
    So the wife gets home form work today and says the Battery light is on on her car.
    So we go out for tea, and on the way home the check engine light comes on, and soon after the car loses a lot of power. (Barley able to get car into driveway). And lights go dim. Stereo loses power.
    I'm hoping it's something simple like the alternator, but thought i'd check here for second opinions first before i replace something that doesn't need it lol..
    VS Series II
    Thanks for your help..
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like the battery and/or the alternator failing to keep the electrical power up. First check how old your battery is - if over 2 years replace, then start the engine and measure the volt across the terminals when at about 1000rpm - if under 13V then its possible the brushes in the alt are gone. This can cost as little as $50 if you do it yourself.
    Commodores need full electrical power and anything under 12 volts cuts the engine generally.
    VS S2
    Aug 2008
    Markings on battery are 03E6, so i'm guessing made in 2006?
    But if alternator was ok then battery wouldn't make much difference, as alternator would be supplying the current?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    In theory yes, as long as the battery is not shorting internally which is very rare...so that leaves the alternator which you can easily check with an multimeter....or a rough check is to turn every electrical appliance on and see if the headlights increase in brilliance when you rev to about 2500rpm. I forgot to add check the battery terminals.....also the heavy cable that bolts to the rear of the alternator - they have a habit of burning thru from fatigue....give it a good wobble (disconnect battery first).
    VS S2
    Aug 2008
    Yeah i was just reading the thread on that issue.
    will check it tomorrow morning, then head to shops to buy a multimeter.
    vy ss ute daily hj gts project
    Aug 2008
    not something simple like a loose terminal i made that dumb mistake a few days ago only hand tghtened it an forgot to do it up tight my car was really sluggish then just died at an intersection
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Yeah check that wire on the alternator, i havnt seen it but it sounds like its a common thing from what iv read, if not it sounds likely its the alternator, unless like said above the battery is shorting out. The alternator should keep the car running normally if the battery dies.
    Reaper
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No it won't. If the battery dies, the alternator will direct it's current to the battery rather than the rest of the car. Check the condition of the battery first, check that the alternator's out put is over 13V, and check the main feed wire from the back of the alternator to see if the insulation looks burnt. If it does, cut it back and put a new terminal on it and reconnect it.
    Visit my Facebook page
    VS S2
    Aug 2008
    sitting at 11.40V while engine is running.
    just over 12V while not running, so i'm guessing alternator then.
    The cable at the back seems to be all good.
    Now to work out how to get the alternator off and change the bushes, i assume that's all i do?
    Cheers for the help ppl
    edit: changed the bushes and all's back to normal now..
    Again, thanks for the help
    VR manual
    Jan 2008
    voltage regulator, $62 from repco
    dont replace the whole alternator its just the brushes worn
  1. engine check light came on then went off??
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2011, 11:02 PM
  2. Engine Check Light
    By impressive in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2009, 10:16 PM
  3. check engine light???
    By Youngblood in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-05-2006, 07:45 PM
  4. Engine Check Light
    By pro_gmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2006, 01:51 AM
  5. check engine light!
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 09:02 AM
