Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VR - VS Holden Commodore (1993 - 1997)
VR - VS Holden Commodore (1993 - 1997) Talk about anything relating to the VR - VS Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 31-08-2008, 09:14 PM
Wavez's Avatar
Ride: VR Berlina M5, VL SL
Trade Rating: (0)
Wavez Executive
Default Clunking towards the rear
I have been getting a clunk coming from the rear somewhere but it's a bit hard to pick...sometimes it feels like its just behind my seat...
It would do this when I had the Auto and the auto shaft had new uni's...
Manual shaft on (could do with new uni's soon) but it's the exact same noise.
It does it when I take off in 1st and plant it a little and also turning, from a stop start. Also in reverse turning it seems to do it.
Every bush has been replaced apart from the rear sway bar, mounts on diff, pin bushes.
They look a little worn. I have been meaning to to replace them.
Would this be the cause? I can't see it being a worn diff...
Does the rear sway bar stop the diff from moving up and down for the tail shaft etc?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 01-09-2008, 05:30 PM
greenacc's Avatar
Ride: VS Acclaim S1
Trade Rating: (0)
greenacc Executive
It has IRS yes ?
Could the noise actually be coming from the front ? I have a noise like that and its one of the front bushes. I guess any worn bush can make that noise.
Sway bar is not actually connected to the diff from memory, but if its loose could still be clunking. Turning would put a bit of load on the bar.
  #3
Old 01-09-2008, 05:45 PM
Wavez's Avatar
Trade Rating: (0)
Wavez Executive
Cheers for reply the front looks all good and sorry it's a live axle.
  #4
Old 01-09-2008, 06:13 PM
ephect's Avatar
Ride: VS Acclaim V6
Trade Rating: (0)
ephect Calais
im thinking centre bearing.. bearing in the middle of your tailshafts.
__________________
Quote:
My mate failed his agriculture exam the other day. He thought a rotary hoe was a chick who screws in the back of a mazda.
Stuff for sale: http://forums.justcommodores.com.au/...tml#post877898
Support the system that supports you. Click the scales and give Rep where its deserved!
  #5
Old 01-09-2008, 06:18 PM
Burnout, Burn What out?
Ride: VS Berlina V6
Trade Rating: (0)
DannyboyDS Statesman
had a look at the auto/gearbox mount recently?
I think you will find that the shocks/springs stop the diff from smacking your floorpan, that and the rubber bump stops (My bump stops look like they have never made contact with the diff)
__________________
My Berlina << Link
Quote:
Originally Posted by Philthy View Post
Then pedal home as fast as you can because you might miss pony club
  #6
Old 01-09-2008, 07:00 PM
Wavez's Avatar
Trade Rating: (0)
Wavez Executive
mmm I cut those bumpstops above the rear to give the shocks more travel and made a huge difference but it's not from that.
Thinking something along the lines of the tailshaft moving around.
I get no vibration driving so don't really think it's the center bearing, it is the exact same noise with the other center bearing...
  #7
Old 01-09-2008, 07:05 PM
ephect's Avatar
Ride: VS Acclaim V6
Trade Rating: (0)
ephect Calais
Quote:
theres only 1 centre bearing lol do you mean uni joint?
__________________
  #8
Old 01-09-2008, 07:19 PM
Wavez's Avatar
Trade Rating: (0)
Wavez Executive
Quote:
I know. The other tailshaft (the whole auto tailshaft)
  #9
Old 01-09-2008, 07:51 PM
Wavez's Avatar
Trade Rating: (0)
Wavez Executive
So could it be the rear sway/stabilizer bar making the diff move or is it my diff that is a fault?
But I really can't see it being the diff because noise is only when turning and accelerating from a stand still. A quick clunk then it doesn't do it anymore.
Could it be a coincidence that both center bearings were worn the same amount and causing the exact same noise?
  #10
Old 01-09-2008, 08:24 PM
V-Josh-R.'s Avatar
NEED PACEMAKERS.
Ride: 94-VR Commodore Ute
Trade Rating: (0)
V-Josh-R. Executive
It could be the bolts being loose that connect the Tail shaft and Diff flanges. If it is dont just tighten the bolts, fit 2 new flanges because its most likely that the bolt holes will become elongated which makes it dangerous ofcourse.
__________________
Holdens go fast...very fast.
FORD:
First
On
Rubbish
Dump
:P
S> CLEAR REAR BRAKE LIGHTS (From a VR ute),GOOD CONDITION, $50, PICK UP ONLY 2197 N.S.W.
  #11
Old 01-09-2008, 08:28 PM
Wavez's Avatar
Trade Rating: (0)
Wavez Executive
Cheers Josh but nar I made sure they were tight and not sloppy.
It was doing it before this other tail shaft, and like I said it's the exact same noise.
mmm so does anyone know the symptoms of worn a rear worn sway bar?
  #12
Old 02-09-2008, 12:48 PM
greenacc's Avatar
Ride: VS Acclaim S1
Trade Rating: (0)
greenacc Executive
sway bars don't actually wear , but the bushes / links do. They should be easy to replace on the live axle, and pretty sheap. The lower trailing arm bushes are always a likely suspect in the rear end as well.
  #13
Old 02-09-2008, 01:13 PM
Ride: VS V6 Calais
Trade Rating: (0)
Dan VS 231 Executive
Is this clunk happening when going over bumps? Ive heard stories and seen the effects of too low commodores that have the rear uni where the tailshaft meets the diff smacking and actually wearing a hole in the floor pan.
Not saying you car is too low at all but with the smaller bump stops it could be one idea. More than likely not but it has happened.
  #14
Old 02-09-2008, 05:02 PM
Ride: vs clubsport
Trade Rating: (0)
mr_clubby96 Executive
ive also got a knock towards the rear and 2 mechanics told me its the diff so i better save sum $$$$$$ knowing my diff is on its way spewing
Digg this Post!
