Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VR - VS Holden Commodore (1993 - 1997)
VR - VS Holden Commodore (1993 - 1997) Talk about anything relating to the VR - VS Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 01-09-2008, 06:32 PM
HK-VS's Avatar
Ride: VS ECOTEC
HK-VS Hitchhiker
Default Water trailing from tail pipe Vs
Gday this is my first post....There always seems to be water-condensation coming from the tail pipe on my vs...Is this normal?there isnt any bubbles in the radiator.Also the temperature is always just over half...Cheers HK-VS
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 01-09-2008, 06:43 PM
Ride: VS11 BTI
Trade Rating: (0)
hako Calais
Welcome
In cold weather thats normal till the engine has reached normal operating temperature which may take up to half an hour if its below zero. Your temp readings sound OK.
  #3
Old 01-09-2008, 07:05 PM
sircruisealotVS's Avatar
Ride: VS Equipe series ll
Trade Rating: (0)
sircruisealotVS MonarosircruisealotVS Monaro
unless its literally pouring out its normal, like hako said.
part of the work the exhaust does (well the cat anyway) is turn unburnt hydrocarbons into carbon dioxide and water - usually the exhaust is that hot that it wont drip out as a fluid but evaporate into steam - but if its isnt up to operating temp yet some water will run out.
when you say "there always seems to be water/condensation" coming out, do you only do short trips? its probably a case of not being driven long enough to warm up the exhaust fully so it always seems to be doing this.
__________________
Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
Check out my V6 blown stroker here: cruisies VS
  #4
Old 01-09-2008, 09:32 PM
SKNOT9's Avatar
All hope is gone
Ride: VS Acclaim SII 3.8L Auto
SKNOT9 has disabled reputation
temp should not be always over half. mine struggles to get above a quarter, unless waiting at lights where it creeps to just below half. Are you losing any coolant? check under the engine oil cap to see if there is any creamy white crap. I just changed the inlet manifold gaskets on mine and they were rooted, and they were already replaced since factory.
  #5
Old 02-09-2008, 07:47 AM
HK-VS's Avatar
Ride: VS ECOTEC
HK-VS Hitchhiker
Thanks for everyones feed back,Cheers HK-VS.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Water In Tail Lights! VR S-PAC... VR - VS Holden Commodore (1993 - 1997) 4 02-09-2007 09:07 PM
Plastic flange or pipe for water hose valet_dave VN - VP Holden Commodore (1988 - 1993) 4 15-01-2007 05:44 PM
exhaust pipe looks like a water sprinkler under revs??????? Matt_vp VN - VP Holden Commodore (1988 - 1993) 7 17-04-2006 09:22 PM
vn tail lights fillin up with water.. OFFiTS VN - VP Holden Commodore (1988 - 1993) 16 27-03-2006 09:15 AM
Celebrity News | Pozycjonowanie | Fast Loans | Personals | Hosting | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
