Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VR - VS Holden Commodore (1993 - 1997)
VR - VS Holden Commodore (1993 - 1997) Talk about anything relating to the VR - VS Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 01-09-2008, 08:36 PM
vsv8berlinawag's Avatar
Ride: VS 5 ltr Berlina Wagon
Trade Rating: (0)
vsv8berlinawag Executive
Default 5 Litre Ignition Module
Does anyone know where one can buy the transistor that sits on top of the module (and what to ask for i.e. part no, spec etc ?). I'm told that this is the part on these units that are prone to breaking down ???
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 01-09-2008, 09:20 PM
vlv8vic's Avatar
Smarter than you - JC Mod
Ride: Mercedes 280SE
Trade Rating: (0)
vlv8vic Grangevlv8vic Grangevlv8vic Grange
moved to proper area (twice -i stuffed up the first time!)
__________________
New posts
  #3
Old 01-09-2008, 10:26 PM
Ride: VS11 BTI
Trade Rating: (0)
hako Calais
I'm just guessing as I'm not familiar with the V8 but if its just a power transistor it will have an I.D. stamped on it and be available from Jaycar, but to replace the transistor you probably have to disassemble the module which is probably designed not to fixable....just a guess.
  #4
Old 02-09-2008, 12:03 AM
Trade Rating: (0)
It is only held in by 3 solder points from the inside + the 2 nuts on top. Mine has 2 of the centre numbers missing from the stamp
  #5
Old 02-09-2008, 10:52 AM
Ride: 94 VR Calais V8
Trade Rating: (0)
Helicopter Executive
If you cannot find the part number or its equivalent, a suitable replacement is the BUX-80 which Jaycar don't appear to stock [that was a great lot of help right?] or the MJ10012 Jaycar P/N ZT2222 for about $11. Its not a simple power transistor, and has a very high breakdown voltage rating with is necessary for switching the ignition coil.
Problem may be that the one on the module may be a PNP type polarity whereas the one's mentioned above are NPN polarity. The transistor polarity may be easily checked using a multimeter [I can tell you how to do this as its simple] but if its blown then obviously it can't. But the chances are in your favour as in all the electronic ignition systems I have either designed in the past or come across, the transistor used is an NPN type.
Alternativelly go to the wreckers and get a price for a second hand ignition module, as it may be cheap enough not to bother with all of the above hassles.
Good luck
Last edited by Helicopter; 02-09-2008 at 10:53 AM. Reason: Wrong transistor wording
  #6
Old 02-09-2008, 10:59 AM
Reaper's Avatar
Tells it like it is.
Ride: VE SS-V, VP SS
Reaper GrangeReaper GrangeReaper Grange
I have one for $100 if you are interested (whole module). Can see it working when you pick it up.
Reaper
__________________
  #7
Old 02-09-2008, 06:25 PM
Trade Rating: (0)
Thanks Reaper, but mine is still working, but from what Helicopter is saying I'm keen to sus out the part and keep it handy as these modules are getting on in age now and hopefully when mine craps itself I'll try and replace the transisitor.
  #8
Old 29-09-2008, 08:27 AM
Trade Rating: (0)
Good luck
Can you please explain how to test the transistor to determine its polarity. I thought I had the problem licked as I went through the module and resoldered any joints that I could get to. The engine didn't miss a beat for about 3 weeks until last #%%## weekend!
  #9
Old 30-09-2008, 11:04 AM
Trade Rating: (0)
Mate, are you located in Sydney?
Yep, I agree these modules are getting scarce, but the power transistor is not the only component that may go faulty or as in your case intermittent [I wish it was the case]
There is an IC inside which receives a signal from the fuel injection computer to advance or retard the ignition.
Anyway if your not in Sydney I will try to describe how to measure the power transistor.
  #10
Old 30-09-2008, 05:46 PM
Trade Rating: (0)
No I live in sleepy old Adelaide. I did some checking at our Jaycar shop and found the transistor that you described, but it had only 2 connectors, where I am pretty sure mine had 3 ???. Any info would be appreciated....thanks
  #11
Old 02-10-2008, 10:20 AM
Trade Rating: (0)
Quote:
OK, you got me ! Can you possibly describe this in detail? Since I can only see the top of the transistor, it looks exactly like a standard T0-3 package. If you look at page 101 of the 2008 Jaycar catalogue, on the right hand side of the page it shows what a T0-3 transistor configuration looks like. If your transistor has 3 pins sticking out the bottom then I have no idea what it could possibly be. I have never come across a T0-3 transistor with 3 pins so I'll wait for your confirmation.
  #12
Old 02-10-2008, 07:15 PM
Trade Rating: (0)
Here it is......
  #13
Old 03-10-2008, 09:45 AM
Trade Rating: (0)
I have never come across a device that looks like a standard T0-3 transistor from the top but has 3 legs! When you mentioned this I thought perhaps you had one too many beers, but clearly you are correct.
The only option remaining is to decifer the Delco part number assuming its still visible and try looking for this part on the internet. Anyway just post the part number and I will try to look it up, but I don't promiss anything
