Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VR - VS Holden Commodore (1993 - 1997)
VR - VS Holden Commodore (1993 - 1997) Talk about anything relating to the VR - VS Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 03-09-2008, 10:16 AM
Ride: VS Ute S2
vs_ute_89 Executive
Question Temp. gauge reading
I have a VS series 2 ute with an ecotec V6 engine which has done about 145,000kms. I replaced the temperature sender about 12 months ago and now every time the ignition is turned on the temp. gauge reads off the scale (past the highest point). I know that it isn't due to the engine being hot as you only have to turn the ignition on for this to happen. If anyone has ideas on how to rectify this problem it would be much appreciated.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 03-09-2008, 04:13 PM
Surfwagon's Avatar
VS2 L67 Wag, New BBS 18's
Ride: VS11 S/C V6 BerlinaWagon
Trade Rating: (0)
Surfwagon Berlina
It sounds like the wiring is earthing, have you connected it back on properly.
Does the reading stay high all the time.
__________________
My ride: VS11 Berlina Wagon L67 w YT Stage 2 Intercooler, snout, 67mm pulley and 1.9/1.95 ultralite RR's. SV5000 Leather interior, VT1 HSV front and VN GrpA rear brakes with BBS RK 18"x8.5" wheels.
View here:
http://forums.justcommodores.com.au/...ad.php?t=52215
or
http://www.l67torque.com/viewtopic.php?t=139
  #3
Old 03-09-2008, 04:38 PM
Banned
Ride: 304 Calais
vnv8driver Calais
yep chances are something is earthing out through that particular circuit and causing this.
  #4
Old 04-09-2008, 11:13 AM
V-Josh-R.'s Avatar
New Shocks
Ride: 94-VR Commodore Ute
Trade Rating: (0)
V-Josh-R. Executive
Thermostat on the way out?
__________________
Love my ute, My first car.
  #5
Old 04-09-2008, 03:18 PM
Ride: VS11 BTI
Trade Rating: (0)
hako Calais
Two questions:
1....did you fit the correct replacement sensor and not a generic
2....has the gauge misread precisely from the day the new sensor was fitted.
  #6
Old 04-09-2008, 03:49 PM
jas98's Avatar
Ride: vs commodore V6 series 2
Trade Rating: (0)
jas98 Berlina
Quote:
wont be that cause he said it happens when he turns the ignition to on. If it happened while driving then i would suggest what you said
anyway id say wiring is dodgy somewhere (short?)
  #7
Old 04-09-2008, 08:08 PM
Ride: VS11 BTI
Trade Rating: (0)
hako Calais
Please read the original post again - he says it happens when he turns the ignition to on - there is no mention that it goes "normal" when driving.
  #8
Old 04-09-2008, 11:26 PM
Ride: VS Ute S2
vs_ute_89 Executive
The reading does stay high all the time, it doesn't move at all until the ignition is turned off again.
  #9
Old 05-09-2008, 08:26 AM
Ride: VS11 BTI
Trade Rating: (0)
hako Calais
Try replacing the original sensor - for the gauge to read hot continuously there must be a dead short either in the sensor or the wiring but if you haven't touched the wiring then that gets back to the sensor - check the 2 terminals for continuity. For under $10 you can buy a digital multimeter that will measure this for you plus if you read the accompanying instructions you'll find the multimeter a handy item.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Temperature Gauge: reading? Morton VN - VP Holden Commodore (1988 - 1993) 13 21-09-2007 05:55 AM
Where does your V8 temp gauge sit V8 Berlina VN - VP Holden Commodore (1988 - 1993) 22 16-04-2007 03:19 PM
vl temp gauge frankyj54 VL Holden Commodore (1986 - 1988) 6 26-09-2006 10:22 PM
Temp Gauge Mr_Calais VB - VK Holden Commodore (1978 - 1985) 2 18-07-2006 06:26 PM
Temp Gauge !!!!? Turbo_dreams VN - VP Holden Commodore (1988 - 1993) 8 04-06-2006 12:14 AM
Indoor Flag Pole Sets | Loans | Credit Cards | Credit Cards | Free Advertising | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
