Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VR - VS Holden Commodore (1993 - 1997)
VR - VS Holden Commodore (1993 - 1997) Talk about anything relating to the VR - VS Holden Commodore.
Reply
LinkBack (2) Thread Tools Display Modes
  #1
Old 03-09-2008, 09:58 PM
SKNOT9's Avatar
All hope is gone
Ride: VS Acclaim SII 3.8L Auto
SKNOT9 has disabled reputation
Default Very loud tapping coming from top end. URGENT please help!!
Ok i have done a search and cant find anything like my ticking being talked about. On the weekend i replaced the inlet manifold gaskets and dropped the oil and new oil filter. a have been driving about 100km since i worked on it and i go out to start it up tonight and it is making a chronic ticking/tapping noise sounding like it is coming from the plenum chamber. And this isnt just some little old engine ticking, it sounds so unhealthy that i dont feel comfortable driving my car until it is fixed, and im taking my GF to the show saturday so i need my car!!, it gets louder and increases frequency as RPM in increased. Is i would have instantly thought it was from the work i did on the weekend but it drove fine for a couple days. Does anyone have any idea what this is. PLEASE HELP!!! ps my car is also reving at about 500rpm on idle now since the ticking started, used to be about 800rpm
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 03-09-2008, 10:00 PM
Peanuts Inc.'s Avatar
Ride: 355 VG :)
Trade Rating: (2)
Peanuts Inc. Caprice
sounds liekone of your lifters is blocked from carbon or gasket deposits or has had coolant in it from taking the manifold off, it happens alot when the manifold gaskets are changed
run some engine oil flush thru it and see if the problems goes away, if it doesnt then track down the suspect lifter and replace the pair of them for that cylinder
  #3
Old 03-09-2008, 10:05 PM
SKNOT9's Avatar
All hope is gone
but how come it didnt happen straight away?
  #4
Old 03-09-2008, 10:08 PM
Ride: 355 VG :)
Trade Rating: (2)
a piece of carbon could of dislodged from the manifold after you put i back on and blocked a lifter or pushrod gallery.... could of been floating around for a while and eventually jammed itself somewhere
  #5
Old 03-09-2008, 10:14 PM
SKNOT9's Avatar
All hope is gone
so to check i need to take off the rocker covers and take a peek?
  #6
Old 03-09-2008, 10:16 PM
Ride: 355 VG :)
Trade Rating: (2)
run the oil flush thru it first.... if it doesnt go away then check your liifters
  #7
Old 03-09-2008, 10:24 PM
SKNOT9's Avatar
All hope is gone
u just mean adding the additive? or re filling the oil? sorry for the dumb questions lol i appreciate the help
  #8
Old 03-09-2008, 11:13 PM
Classifi3d Calais's Avatar
9-11-08 CRUISE FOR KEBAB
Ride: VE SV6, 52 Morris Coupe
Classifi3d Calais Calais
drop the oil again and start fresh,
is the noise from the driver or passenger side bank?
  #9
Old 04-09-2008, 12:19 PM
SKNOT9's Avatar
All hope is gone
neither, or both. middle? lol sorry but yeh like i said it sounds like its coming from the plenum chamber, opened it up, had a look, cant see anything
  #10
Old 04-09-2008, 12:52 PM
Ride: VC SLE Commodore 3.8l
caseyhelen Executive
hows your oil psi i had the same problem on a vn abit of gasket made it to the sump
than the oil pick up , started as soon as i put it back together makes it sound like a lifter
  #11
Old 04-09-2008, 03:14 PM
Ride: N/A
Trade Rating: (0)
DavoVP Executive
I have the same ticking on my VP, except mine comes and goes as it pleases, rear right. Narrowed it down to the lifters. Gota replace em eventuly.
  #12
Old 04-09-2008, 05:49 PM
SKNOT9's Avatar
All hope is gone
had a closer listen realised it is in the passenger side rocker cover. when i was pulling the rockers off i noticed that one of them can rock even though the bolt is done up tight. its like the rod is too short and not pushing the rocker up enough
  #13
Old 04-09-2008, 05:58 PM
greenacc's Avatar
Ride: VS Acclaim S1
Trade Rating: (0)
greenacc Executive
could be a dud lifter , but funny it just started after you worked on it. I reckon its a piece of crap stuck in there as above. Hydraulic lidters need oil pressure to work so if one gets blocked it don't lift properly..
