Almost certainly the spark plug leads. Under load they break down through the insulation and short out, which means the cylinder doesnt fire and you get the jerk. Start by replacing the spark plug leads, full set will set you back about $50. You might as well do the spark plugs while you are there for around $12 for a full set (of 6, assuming we are talking about a V6). Do one lead at a time (so you dont get them mixed up) and you should be purring again in no time.
Not going to be anything to do with the fuel filter.
LinkBack URL
About LinkBacks
