Results 1 to 7 of 7
Thread: clunking noise coming from the rear?
    vs clubsport
    Aug 2008
    Default clunking noise coming from the rear?
    hey guys i have this clunking sound coming from the rear i noticed when i change gear from 1st to 2nd n 2nd to 3rd theres a clunk sound between gear shifts also when i down gear the revs drop nice n smooth until down to 30kms it goes clunk clunk there then car stops would anyone know wats the cause of this problem cheers
    VT V6 Acclaim
    Dec 2006
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Get the car up on ramps and check the entire driveline for wear/looseness....it could be a worn centre bearing, worn uni's either on propshaft or halfshafts (presume you're IRS). Look for witness marks where the clunk has left a mark. Rear engine mount should have no movement. Then you move onto the IRS!
    vs clubsport
    Aug 2008
    ok mate sweet no dramas ive got from 1 mechanic which thinks my diff is the problem but also seems unsure about the problem but im also looking into it more cheers guys thanks
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Is the car fitted with IRS and if so check that your diff cradle hasn't cracked which is a common VR/VS IRS problem.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    vs clubsport
    Aug 2008
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Do a search on here regarding IRS cradle cracking, has been covered before.
    Cracking was in a RTA inspection notice for VR/VS IRS commodores for rego inspections.
  1. Annoying rubbing noise coming from rear
    By Raging Bull in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 06:03 PM
  2. Rear Axle Clunking Noise - Help needed
    By jazza21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2008, 05:35 PM
  3. squeaking noise coming from rear axle
    By ciaranvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-08-2006, 01:56 PM
  4. clunking noise from the rear of the car
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2006, 06:29 PM
  5. Clunking Noise
    By blade_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2005, 12:57 AM
