Results 1 to 12 of 12
Thread: VS Heater Tap Hoses
    VS
    Oct 2008
    Question VS Heater Tap Hoses
    Hi,please excuse this post,but im not very mechanically minded.
    Ive just replaced the Heater tap in my VS,and i think i may have reconnected the hoses around the wrong way.The hose that comes from the top left side of the block,does that connect to the top or bottom connection of the heater tap?
    Sorry about this,Thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    VS
    Oct 2008
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    know the feeling, my heater tap blew up this year too. Plastic only lasts so many years..
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    hey guys, after 3 hours online trying to figure out what i blew up last night on the VS i have arrive at the conclusion that its the water tap - sorry im still lerning about cars/mechanics 2, heres the story, got home from work last nite and the flatmates had some mates arround, wanting to show off the power of my pride and joy i did the obligatory burnout, once the driveway was sufficantly smokey and black i rolled forward into the garage, noticed steam coming out of the engine bay, promptly pood in pants then tryd to figure out what id done, found out it was the water tap (ive only just found out what its called) the top hose connection just plain broke off ( were the hose from the water pump connects to the heater tap)
    HERES THE IMPORTANT QUESTION!!
    seeing as the heater tap has broken is there any other damage that could have been done to the engine when it broke or as a resault of it breaking?
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    only if you let overheat and kept it running.
    No it will be ok by what you have written.
    When you replace it take sure you bleed the system and get all the air out.
    I run my car for a couple of days with the heater fully open and bleed it when I get to work. On day 3 no more air comes out all good.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Nov 2008
    rotorua, NZ
    thanks heaps bro!!
    so let me get this right
    there should be no other damage and to change it i simply remove all the hoses, unbolt it and attach the new hoses then bleed the system
    what do i do about the little metal thing on it? sorry i dot know what its called
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Thats the vacuum servo that turns the tap on/off. Once you remove the tap you'll see how it attaches to the new one. The tap I bought from Holden had vacuum servo included with the tap but I think they also are available without the servo. Take a digital pix of it before you pull it off then you can't go wrong.
    VS_Pete_1's Avatar
    Dec 2007
    Thats what I was going to say.
    Cheers mate
    Nov 2008
    rotorua, NZ
    hey guys thanks for all your help! i realy apreciate it!
    i managd to get the part, install it and get it ready to go, its workin fine and there seems to be no problems with it
    your legends
    thanks again!
    VS_Pete_1's Avatar
    Dec 2007
    cheers bro
    VS_Pete_1's Avatar
    Dec 2007
    Once a week I open the valve all the way open just to keep it freed up.
    They can sieze up over time.
LinkBacks (?)
  1. 16-01-2009, 06:09 PM
  1. Leak from heater hoses or valve??
    By BobEddie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 06:39 AM
  2. New heater hoses now no heat?
    By fergies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2008, 03:16 AM
  3. Vac hoses for heater system
    By dixie265 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2007, 08:28 PM
  4. Best way to remove heater hoses at firewall
    By commodore2004 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-08-2006, 05:42 PM
  5. Suspected leaking heater core or hoses.
    By fazz1977 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2005, 11:54 AM
