Results 1 to 10 of 10
Thread: Central locking not working
    bhagl1 is offline Brendon
    96 3.8L VS Ute
    Oct 2008
    Default Central locking not working
    I installed a new sound system today and now my central locking doesnt want to work. When I push the lock button the lights flash as if its locked but it doesnt lock and same with unlock. When I lock it by key the drivers side door locks but the passengers does'nt. Any suggestions???
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    96 3.8L VS Ute
    Oct 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you pulled the door trims off to fit new speakers its quite easy to jam one of the door lock knobs especially the drivers one. Check that each lock knob moves up or down.
    Is the immobiliser unlocking (like can you start the car)?
    96 3.8L VS Ute
    Oct 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Seeing as it happened with the new sound system you'll need to go back and check every connection you made when installing the new unit. Have you tried disconnecting the battery....sometimes this can reset things.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Theres a connection inside the drivers door for the main locking mechignism.
    Check to see if the connection hasnt come apart
    94 vr ute
    Oct 2008
    Quote Originally Posted by hako View Post
    Ahaa!! thanx bud, ill be checkin that one out, sounds like the symptoms of the prob i'm having.
    LightningVP is offline Donating Member
    None
    Sep 2008
    (in responce to your post in the How To)
    Not sure when they changed things like that, I know VR/VS, when you lock with key you turn to the left (about 45o and it springs back, then if you want to double lock, you do it the full 90o, I know my car is stuffed, with my drivers side, I can't lock the door with the car (but I can with the passenger side) and my back left lock doesn't work, have to do it myself (was told this is a common problem with that door)
    94 vr ute
    Oct 2008
    just pulled the trim off, a few hassles but i got there, only to find that there isnt a central locking mechanism/wires etc..!!! grrrr. tried turning the key a full 90° and she wont go, only gets to 45 and feels as far as it will go but still doesnt engage full lock no matter what i do. oh well, my main mission was to suss out the c/locking, the other issue with unable to unlock from the inside etc can wait. a bonus was i got to see the type of speakers the previous owner put in, 6inch kenwoods. not bad but could do better. one thing i did find but not sure if its normal is like kind of a loose end of the rubber seal on the inside near the mechanism, investigated it and it isnt interfering with the lock so that isnt to blame. anyway, thanx for the replies, i'm sure i'll have something else to ask later on down the track.
LinkBacks (?)
  1. 31-10-2008, 07:29 PM
  1. Central Locking not working
    By t6a9r in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2008, 12:09 PM
  2. Central locking and pwr windows not working?
    By Malus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 11:22 PM
  3. Central Locking not working
    By RedGoesFaster97VS in forum Electrical Wiring / Questions
    Last Post: 14-08-2006, 09:03 PM
  4. VN - Central locking not working
    By enrico in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2006, 02:48 PM
  5. oh no, not working - powerwindows, central locking
    By jessedevery1 in forum Electrical Wiring / Questions
    Last Post: 26-06-2004, 01:23 AM
Tags for this Thread
