Results 1 to 4 of 4
Thread: ecotec inlet manifold on buick?
    S1 VR V6 BT1
    Mar 2008
    telarah
    Default ecotec inlet manifold on buick?
    Hey,
    Quick question:
    Will an ecotec inlet manifold bolt up to a VR buick motor with minimum hassle?
    My Ride:
    '94 VR V6 BT1. 15" roh with 225's, stocky with bellmouth removed, OTRCAI, homemade airfilter, B&M Stage1 shiftkit, .490 boost valve. Corvette servo.
    Lappy runnin EFILive in a semi stock interior.
    WANTED: VN/VP/VR/VS Standard
    Memcals.
    WANTED: Standard front bar from VR/VS. Prefer alaskan white but will take anything.
    Newcastle/Maitland/Central Coast.
    Email me
    hyp3r4l3rt@hiptop.com.au
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    short answer,no
    the vr block is i think around ~10mm wider, so it will sit in the vally ok, but wont bolt to the heads.. hakhawk will be able to confirm thou, he's toying around with buick cross ecotec
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    Jan 2005
    block is more around 20mm wider.
    you would need to bolt the ecotec heads on as the port layout is completely different. then you need to make spacers to fill the gap of the block width(this isnt as easy as it looks, nothing lines up straight), then get a custom camshaft made to suit the new IEIEIE firing of the ecotec vs IEIEEI of the pre-ecotec.
    in short, stick with the buick manifold, or buy a whole ecotec, unless you're ready to do the hard yards and spend $$ on getting it right.
    VP Executive R-spec
    Jan 2005
    The quickest and best way to get an ecotec manifold in there is just put the whole motor in 50x less time, easier and cheaper, then you get the heads too
  1. Ecotec V6 Inlet manifold
    By enhancedss in forum V6 Development And Modification
    Last Post: 31-07-2008, 07:08 PM
  2. Buick Series 1 and 2 inlet manifolds
    By 202injected in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2008, 08:13 AM
  3. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 09:23 PM
  4. WTB: Ecotec Inlet manifold
    By GMH-DVL in forum Swap / Wanted to Buy / Trade
    Last Post: 04-06-2006, 09:30 PM
  5. Buick Inlet manifold
    By AirStrike in forum V6 Development And Modification
    Last Post: 17-02-2006, 07:35 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
