Results 1 to 19 of 19
Thread: car missfiring 1995 vs v6
    Mar 2008
    Default car missfiring 1995 vs v6
    as it says my 1995 vs v6 is missfiring well i think it is. driving a long then it misses .i have just changed the crank sensor,cam sensor,and the 2 oxygen sensors.any ideas what is causing this.was doing it before all the new sensors.could it be the thing under the coils the dfi sensor.i think thats what it is called and has new sparkplugs as well .
    7 snakes 4 kids 1 wife 1 ea falcon 1 vs dunny door
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    Mar 2008
    no just driving normaly around the streets at 50 km hour and other speeds
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    could be a coil or the leads. Does it miss under load when you put yur foot down ?
    Mar 2008
    yes and when it is at a stable rpm coasting
    greenacc's Avatar
    VE Berlina
    Jul 2008
    how old are your leads ? have a good look at them for any deep rub / burn marks on em that will cause a miss. you might be able see sparks from the leads or coils if you watch it idle / rev in the dark, worked for me when it was my coil
    VS Standard
    Oct 2008
    im having the same sort of problem with my 98 vs
    if happens after a while driving like 20 mins
    at sometimes its at 3-4 k
    and sometimes a 4-5 k
    every time it does it is ****es me off!!!
    Mar 2008
    wi;ll replace leads and dfi modual and do the coils as well wont hurt
    VRII Acclaim
    Jul 2005
    You can first narrow it down to which cylinder is not firing. You do this by disconnecting the connector on the injector while the car is running, one at a time. When you disconnect the injector petrol is no longer injected into that cylinder and the car will instantly change the way it is running. This will happen on all cylinders EXCEPT the faulty one. As the faulty one is not firing the engine will not change at all.
    Once you know which cylinder is not firing you can check a couple of things.
    Coil packs. You can measure the primary resistance and secondary resistance. Primary is on the bottom of the coil. You need to remove the coil and measure the resistance between the two connectors on the coil. You should get something around 0.6ohms.
    To measure the secondary you measure between the two connectors on the top of the coil that you would normally connect the spark plug leads on to. The resistance should be between 5 and 7 kilo ohms (5000 to 7000 ohms). I have found coils to be around 8kohms and they will not fire, causing this bad idle.
    But definitly start by narrowing down the cylinder. You can also check that the spark plug doesnt have any gunk on it that would stop it firing.
    New coil pack can be purchased for around $55 from repco or around $75 from holden, $100 for some MSD coils (claim to be a little better). Even cheaper if you went to the wreckers.
    Let us know how things go.
    VRII Acclaim
    Jul 2005
    Quote Originally Posted by WAC-988 View Post
    mate your problem might be the spark plug leads. Start by replacing them. What you have is a breakdown under load.
    Mar 2008
    finally fingers crossed it is fixed
    after 1 cam sensor/1 crank angle sensor.1 dfi modual/2 oxygen sensors and 1 coil pac
    it was the coil pac
    running real good now doesnt miss a beat touch wood
    i will get the other 2 coil pacs when i get more money
    this forum is so good i will be asking hear first before going to the machanics from now on
    mrhotdog is offline What Would Jesus Do?.....
    2003 VY S1 Acclaim
    Nov 2007
    Adelaide, South Australia
    Mar 2008
    the stupid thing is still cutting out not miss firing any more
    stalling while driving i dont know why running perfect then it like it turns off
    starts straight away ????????? help i am going insane trying to find out why
    VRII Acclaim
    Jul 2005
  15. #15
    greenacc's Avatar
    VE Berlina
    Jul 2008
    bugger ey, solve one problem get another. Was it cutting out before all this work or is that new ? I can only guess that the cutting out is DFI related or a loose connection/damaged wire in the dfi harness somehwere. check the codes as kopper said, there should be a code or 2 logger after all this.
  16. #16
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Just a tip... may or may not solve the problem.
    Change the leads and plugs, If it is still missfiring... check the coils arent loose.
    Sometimes the bracket the coils sit on can loosen.
  17. #17
    Mar 2008
    auto electrication thinks it is the crank sensor so getting another put in tomorrow
    running nice now only turning it self of when driving
    the crank sensor i got the first time was a cheapie off ebay the car ran fine for 6 weeks then started turning its self of when driving so getting a top quality one this time
    hopefully this works .
  18. #18
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
  19. #19
    Mar 2008
    had another crank sensor put in it seams to be running fine not cutting out so far
    so i learnt a lesson dont buy cheap parts from overseas buy a decent brand like bosh
  1. VX Supercharged coughing and missfiring on startup + hissing
    By Raging Bull in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-02-2008, 10:24 PM
  2. missfiring under acceleration
    By b3h3m07h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 01:55 PM
  3. Vn Missfiring??
    By VHSLX3300 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2006, 09:53 PM
  4. Dual Fuel VS - Missfiring? on Petrol
    By Wojzilla in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 12:24 PM
  5. Missfiring under load??????
    By slick_red_VN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2006, 07:55 PM
