Results 1 to 9 of 9
Thread: How to Remove Outer Handles and Mirrors (to paint)
    Gen 3 VT2 Berlina wagon
    Aug 2008
    Default How to Remove Outer Handles and Mirrors (to paint)
    As the title says, i want to take off my handles and side mirrors and paint them to match the rest of the car. Can anyone tell me the safe, easy way to do it?
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Mirrors: 1 screw on the plastic cover (same position as where the mirror is but inside the door), undo that... take the plastic off then 2(?) bolts holding it in
    Outer handles: Take off your door trim, then take out a pin that holds the handle together and it should all come apart pretty easy then just wiggle it out...
    i know its not extremely detailed but thats pretty much the idea you will know what i mean when it comes to it
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Aug 2008
    Thanks, ill try it next weekend.
    Are there any wires inside the mirrors, and how would you go about that, because mine has electric mirrors.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    More difficult with electric mirrors. Not totally sure about VS, but i know VRs plugs are lower in the door, so you'll need to remove the door trim aswell.
    After you pull the cover off (with the 1 screw in it, mentioned above) you'll know weather or not you can unplug it from there, or if you need to remove the door trim.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Aug 2008
    ^Yeah, that cable in the door handle can unplug (did it when i changed the speakers last week), but pulling it up through the door and out the top would be difficult to put it back in, so hopefully there will be an easier way. I might just cover the car in newspaper and paint on a calm day. Anyway i'll try it tomorrow hopefully.
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Quote Originally Posted by fuzzy2308 View Post
    will the handle fall apart when i remove it? is it easy to reassemble?
    yes and yes
    Sep 2008
    thanx mate, is the pin that long copper colored thing? i tryed for an hour or more but didnt get anywhere.
  1. Colour Coding the Mirrors - Easy to remove mirrors?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2007, 04:20 PM
  2. how to remove the door handles ??
    By blake_111 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2007, 01:48 PM
  3. Remove door handles for spray painting car
    By travb81 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2007, 09:37 PM
  4. How Do I Remove Door Handles?
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 07:31 PM
  5. changing outer door handles on vl???????
    By dumpd6 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-01-2005, 06:18 AM
