Results 1 to 17 of 17
Thread: Lowering Suggestions
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Default Lowering Suggestions
    Hey Guys,
    Ok, so i got a 1999 VS Ute (pretty much stock) the other day and i want to lower it a little. What do you guys recommend? I dont want it too low as i drive on a fair bit of rough dirt road. I have heard king springs are the way to go, will these even fit my ute? I think the lows would be low enough for what i want, super lows may be a little low for dirt roads, what do you think? I want the front and rear lowered.
    I talked to a guy the other day that said i could even cut a little bit off the stock springs myself if i wanted it a tad lower and save some money, but then some people have told me NOT to do that, what do you reckon? Any other suggestions would be much appreciated!
    2001_VXSS's Avatar
    2001_VXSS is offline keepin' it real
    VR Berlina Series II
    Sep 2008
    hey mate
    i wouldnt get king springs, because they are just CRAP!! if you are wanting to lower your ride a bit but not much i would suggest some FE2 Springs. these springs are a better quality then king.
    lets just say king springs are cheap copys.
    Get a pair of FE2's they will go well in your ride.
    hope that helps
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by Patrick77 View Post
    hey mate
    hope that helps
    although some would disagree
    aussie_cruzin's Avatar
    aussie_cruzin is offline got boost
    T04 turbo r31 skyline
    Jan 2008
    Aussie
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Quote Originally Posted by aussie_cruzin View Post
    DONT cut your springs!
    Ok, i wont do that. I didn't think it sounded like a good idea. Thanks so far guys, keep em coming!
    96 VS & 5spd VT 5.0L VX Clubsport lookalike
    Jun 2008
    Port Macquarie/Newcastle, NSW
    Get king springs they're reputable enough IMO. I have lows in my car if you want an idea of what height your gonna get on stock shocks, if you're on really rough roads maybe look into heavy duty springs?
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by Ozzie View Post
    yeah, like at least one WRC team that runs Kings.
    Ride quality is alot more to do with shocks that springs, because springs have linear compression (not to be confused with linear or progressive rate) meaning that it doesn't matter at what speed the springs are compressed, the same effort is required. Unlike a shock, where the faster the shock is compressed, the more effort that's required, which is exactly what they're designed to do.
    There's a reason why Kings are the largest spring manufacturer in the southern hemisphere...
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    S1 VR V6 BT1
    Mar 2008
    telarah
    Hey bud, Im about to change from fe2 to king springs.
    The springs I'm taking out are in good condition.
    If ya want em when I change em you're welcome to em.
    I'm in the hunter, if ya want em PM me.
    Maybe we can work out a trade or something.
    My Ride:
    '94 VR V6 BT1. 15" roh with 225's, stocky with bellmouth removed, OTRCAI, homemade airfilter, B&M Stage1 shiftkit, .490 boost valve. Corvette servo.
    Lappy runnin EFILive in a semi stock interior.
    WANTED: VN/VP/VR/VS Standard
    Memcals.
    WANTED: Standard front bar from VR/VS. Prefer alaskan white but will take anything.
    Newcastle/Maitland/Central Coast.
    Email me
    hyp3r4l3rt@hiptop.com.au
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    How about lowering blocks? Are they any good if i just wanted to lower it a fraction? Will they effect the ride at all?
    VZ AWD One Tonner
    Jul 2006
    Lowering blocks are for leaf springs, not Coil springs.
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Quote Originally Posted by gslrallysport View Post
    Sorry, i meant those coil spring compressors.
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    I didn't think FE2 lowered the car? my car still looked like a monster truck when it had
    FE2's in it.
    Make sure you don't get cheap shocks either, if your lowering best to get shorter shocks int he rear IF when you raise the car and both wheels are off the ground, you can move the rear springs.
    When I went from FE2 to super lows ( I only wanted lows but someone stuffed up) I could jack the rear up, reach in and remove the rear springs.
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    TIP OF THE DAY
    Ok so I lowered my VT today. IRS ofcourse.
    For the rear springs to come out you need to undo the shock, unclip the brake line (passanger side) and it should drop down?? haha not quite!!
    Some people Ive heard have undone the axel from the wheel side.
    What I did amazed even me lol
    I jacked the car up one side at a time...
    Then undid the rear shock and uncliped the brake line.
    BUT how the hell was I sposed to jemmy the axel down without un-doing it?
    The answer is... I used two jacks. One to jack the car up and one between the axel and chassis. jacking the axel downward with ease and the springs just fell out
    Careful if you do this though because once the axel is jacked down it becomes spring loaded. Safest way to jack it is to have the base facing streight along the axel.
    No need for spring compressors (which I didnt have anyway)
    Once the standard spring was out, it was a matter of holding the lowered spring in place whilst lowering the axel jack.
  15. #15
    vz s pack ute
    Nov 2008
    Alstonville Northen Rivers NSW
    has anyone got an idea wether u can put super lows on the back abd lows on the front
  16. #16
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by boonga View Post
    You can depending which state you are from.
    Here in Victoria they have to be the same height all round.
    as stated in VSI8 vehicle modifaction faq
  17. #17
    1994 VR Exec, 5.0L BT1
    Jan 2005
    I had FE2 springs in the VR, it's about 30mm lower then stock. Threw in some pedders sports ryder coils on the weekend, sits/handles very well. Still a legal height too. I'd definitely reccomend them, you will need short stroke shocks as well. I got monroes put in about a month ago in prep for the new coils
  1. VT Mod Suggestions
    By Jacobjac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2008, 08:36 PM
  2. any suggestions for LJ?
    By lexa in forum Straight 6 Development And Modification
    Last Post: 12-11-2005, 09:34 PM
  3. Lowering a VT... suggestions?
    By yeggles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-08-2005, 09:51 AM
  4. Any Suggestions?
    By ProMaX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2005, 12:18 AM
  5. VN First Car! Suggestions?
    By perrin457 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2005, 08:09 PM
