What are these parts called and where can i get em?
1 The caps that cover the screws on the back bumper
2 The panel under the steering colum is being held on by 2 ugly brass screws, what normally holds that panel on? (im not talking about the steering colum cover)
I live my life quarter mile at a time, For those 23 Seconds nothing else matters
The hinged panel that houses the fuses and what not is usually held in place by some screw in plastic clips. Might be able to pick them up at an auto parts store or Holden for both things.
I believe what you are after are called "plastic pins"
Their just fat round pins that hold the cover on at the bottom.
The same "pins" are used in the glove box
You can get them from most wreckers for next to nothing (theyll probebly just give them to you)
the caps on the bumper are just screw plugs which you could also get from a wrecker if you find the right one
go into your local holden dealer or a wreckers, you'll be able to get those pieces easy....
as for the 2nd pic, the cover has 3 clips that have a slot in the top, once again any holden dealer or wreckers should be able to sort you out
I dont know about number 1. I have a sedan :P. Ozzie shoud be right on about the pins as well.
