Hey guys. I'm trying to find the little white plastic bits that are on the ends of the window winder mechanism in my 2000 model VS ute. They are on the ends of the scissor arms and slide in the channels under the glass. They seem to be included in any manual or power mechanism but can you get them seperately?
cheers
Any ideas anyone. Still looking
Thanks
Your best bet would be to give your local holden dealership a phone call. If you cant get them new you'll have to go to a wrecker.
Many thanks for the reply. I've tried Repco and Super cheap etc but no good without part number. I was thinking the wreckers might be the only place. They will want to sell the whole mechanism complete probably. Cost me $50 bucks for a 2c part.
cheers
Just a quick question guys with my VS Ute. I am looking at replacing the drivers side window mechanism with another one i got from the wreckers which i suspect is in much better condition as my current one makes terrible noises that no amount of grease/spray will fix. Just making sure that the ute did actually use the same size/window mechanism as the sedan right? They didn't make separate parts for the ute and sedan right? I hope not or else i got no clue where i will find a ute window mechanism?
Thanks guys
Matt
VN to VS sedan and ute doors are all the same, so I would be pretty sure that the winder mechanism is the same also.
