Results 1 to 6 of 6
Thread: vr ecotech,again..
    202injected's Avatar
    202injected is offline Quality Engine Builder
    VZ Exec. 3.6
    Oct 2005
    Default vr ecotech,again..
    I know this question has probably been asked a thousand times before, but i am curious,
    If i stick an ecotech into my VR and wire it up to all the VR(buick) sensors and wiring, will the delco run the engine?. i have compared both motors in complete form and most of the stuff is simiale and things like the firing order are all the same, only difference being as my VR is a manual it does not have the cam angle sensor (only autos did).
    alternatively, will it run if i swapped the delco for a plug in haltech?
    any help/opinions/comments please people
    HUNTERMOTASPORT
    Mild To Wild, Your Engine to Your Budget
    no more VK cancer got the better of her R.I.P.
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    I think some of the sensors may throw out different readings between the VR and VS engines.
    It would be interesting to see if you could get it go, I know one thing for sure, if you want to run the VS ecotec and keep your VR ecu you'll be keeping your map sensor and scrapping the VS MAF.
    Other then that I hope someone like Kopper or Abba or about 300 other smarty pants come along.
    VP Executive R-spec
    Jan 2005
    It will run just fine on the stock tune, been done heaps of times on VR's, you need to get the map sensor on. One other sensor needs taping on (see hozys notes). And on the VR's the tps sensor wires need to be put on back to front if you are using the VS throttle body
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    one thing i'm interested in finding out... are ecotecs legal in earlier models without the MAF??? (mine would need to be engineered as I'm going turbo)
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    VP Executive R-spec
    Jan 2005
    If you are going to run a turbo and get it engineered it will need to pass an emmisions test anyway and if it passes that whatever ecu was running it is legal. The test is emmisions test is 2 grand +. If you run straight lpg you get to skip the emmisions test.
    Officialy un engineered/emmisions tested the map ecu on the ecotec isn't legal but it would easily pass the relivent ADR so it's not that big a deal, you wouldn't fail an emmisions test on the VR ecu. I'm a big greeny and I'd sleep easy at night with that setup, I figure if it's good enough for me good enough for the epa legal or not. It's morally OK and in the end that's the most important thing
    VR EXEC
    Dec 2005
    quarantine
    up here we don't need emissions tests. from what i've been told the engineer simply looks at build quality, obviously they check that it'd pass EPA requirements like non venting catch-can etc (venting BOV's are legal so long as they're not excessively loud) and check that other things such as brakes are up to the task
  1. Ecotech in vp is it possible
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2007, 09:13 PM
  2. My New Ecotech VH
    By Secki in forum VB - VC - VH - VK
    Last Post: 18-02-2007, 08:06 PM
  3. VT Ecotech into VP help please :)
    By xlr8_87 in forum V6 Development And Modification
    Last Post: 09-02-2007, 10:05 AM
  4. VL with VS Ecotech
    By pro_gmh in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-09-2005, 11:20 PM
  5. Ecotech in vp is it possible
    By G4orce in forum General
    Last Post: 01-08-2005, 10:20 PM
