Results 1 to 7 of 7
Thread: Help with installing pacemaker extractors to a vs with T5 manual!
    vs v8 5spd 9c1
    Sep 2006
    Default Help with installing pacemaker extractors to a vs with T5 manual!
    Hi. I'm currently trying to install a set of pacemaker headers to my vs which has a T5 Borg warner gear box! As expected the left hand side was a breeze but the right is very tight!
    I followed the instructions and ground the edge of the bell housing back a little. I've tried putting them in from the top and the bottom (I have the car jacked up on stands) but I cant seem to get them in. I was wondering, does anyone know any little tricks to sneak them in? Any advice is most appreciated! Thanks
    Jun 2005
    im installing them on a v8 at the moment, so its even harder for me. i had to jack up my engine a bit on the drivers side, and then it was just a matter of finding the right way to manouevre them in and i eventually got it
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    vs v8 5spd 9c1
    Sep 2006
    yeah thats not a bad idea actually, i could get the jack under the edge of the bell housing and lift it up a bit. did you just unbolt the right hand engine mount?
    Jun 2005
    yeah pretty much, i just jacked it from the motor, using the sump and a block of wood. dont jack from the sump directly
    vs v8 5spd 9c1
    Sep 2006
    yeah cool thanks mate, i'll give it a go tommorrow, even a few mm will make it a bit easier!
    VSSECO is offline Underdog rebuild
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    Yep jack the engine slightly, thats how they'll do it in the exhaust shop
    vs v8 5spd 9c1
    Sep 2006
    Got em on alright, I ended up jackingthe engine up and sliding them through. Cheers for the help
  1. pacemaker extractors
    By Muzz-VS in forum V6 Development And Modification
    Last Post: 03-09-2008, 09:59 AM
  2. V6 extractors - Pacemaker vs Pro-Flo
    By Marks-VY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-04-2007, 11:47 AM
  3. pacemaker extractors
    By AnthsVSLexcen in forum V6 Development And Modification
    Last Post: 07-07-2006, 12:30 PM
  4. Wildcat extractors Vs Pacemaker extractors.
    By rob_phill in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2006, 09:05 PM
