Results 1 to 9 of 9
Thread: Speed stopped working
    VR Executive
    Oct 2008
    Default Speed stopped working
    Hey guys,
    I was using a guide on here to help me replace my dash lights with LEDs, i managed to follow that easily enough but once i put my dash all back together the speedo stopped working... the lights/fuel/rpm etc. are all working fine though, just have no idea how fast i'm travelling.
    Any ideas on what i could have done to cause this? I've checked the cluster lines up with the plugs and that appears to be fine... before i removed the dash the speedo itself was working fine. The trip meter and km reading weren't though... could the issue be related?
    Cursed CX8 is offline Banned
    VY Adventra
    Feb 2008
    Walking distance to FG meets
    there is a connector on the back, id say its come off or one of the wires has pulled. Rip th dash out again and have a look
    VR Executive
    Oct 2008
    Couldn't find out what was wrong, so i picked up another speedo from Pick n Payless. I knew it was the actual cluster itself as my sister has the same model car and i put her speedo in and it worked fine straight away... so i didn't forget to plug anything back in, it just stopped working.
    I have a feeling that the LED's caused it to stop working. Although i'm not sure how that's even physically possible... i'm not sure whether i should try placing the LED's in the replacement speedo or not.
    Is it possible for the LED's to cause the speedo to stop working?
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    not to risk killing ur new speedo. Take the LEDS outta ur old speedo and put that in. If it works then it is the LEDS, if not then i dunno hahah
    Just give that a try first mate.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    VRII Acclaim
    Jul 2005
    VR Executive
    Oct 2008
    Quote Originally Posted by Paiste402 View Post
    Already tried that one. No luck unfortunately. The weird part is that the LED's were working fine, and i can't see how they could effect the actual speedo.
    JJ's VR's Avatar
    JJ's VR is offline VRHLDN
    VR 3.8lt Supercharged 163.8kW & VS sII HSV Senator
    May 2006
    Have you tried giving the top of the dash pad a bit of a whack with a closed fist, not too hard, just a firm whack. Enough to see the needles jump a little. Try that!! (either stationary or driving, doesn't matter) Works for sticky guages, ie fuel, temp and speedo. They tend to "dry out" on the solder join.
    VY S3 V8 Monaro
    Jun 2005
    If it's a VR Series 2 (with the speed alert) try holding down the speed up / speed down buttons (at the same time) as you start your car. This should switch it to a digital speedo. If this works.. means your cluster is receiving a signal and passing it on to the speed alert unit.
    Otherwise check the wiring on the plugs (that go into the cluster) make sure they're all terminating OK into the plug.
    Be careful taking the cluster in / out. I've wrecked 2 so far as the green circuit board rips so easily.
    VRII Acclaim
    Jul 2005
    Quote Originally Posted by johnnyk View Post
    Only the high series VRs will have the speed alert. LEDs wont have anything to do with it. I bet that there is simply a damaged track there somewhere. I would pull apart completely and just keep looking.
  1. My key stopped working.. :(
    By Howks in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-07-2008, 11:52 PM
  2. Speedo stopped working!
    By jay_hman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2007, 11:46 PM
  3. blinkers stopped working
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2006, 11:56 AM
  4. Odometer stopped working in VP
    By jabbavx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-03-2006, 05:44 PM
  5. VT CD/Stereo stopped working?
    By Montaro in forum Car Audio
    Last Post: 29-11-2005, 02:52 AM
