Results 1 to 7 of 7
Thread: Removing drivers door
    VU II SS
    Mar 2006
    Default Removing drivers door
    Hi guys,
    need to remove the drivers door to do some panel work, ive got all the trim off and can get the door off the hinges although unsure what to do about the wiring is there a simple unplug hidden away in it somewhere?
    any help would be appreciated
    skyper is offline SKYPER
    SV6
    Aug 2008
    LISMORE NSW
    u should be able to see a plug inside the door if their was one ,i don't think their is, u will have to undo everything and thread it back through the hole,hope im wrong and u find a plug,its not hard to thread it all through though
    VU II SS
    Mar 2006
    hmmm yeah i think thats what im going to have to do, sucks pretty bad would be easyier if there was just a plug
    '97 VS Commodore + '98 E36
    Apr 2005
    Pretty sure there is a plug...NOT too sure on where about it is, been a long while since i last done a door change, but it definantley has a loom plug.
    Though if i remember you needa take the bottom side plastic on the side of the dash out (aircon outlet that joins the top and bottom vents)?? the plug is like mounted on the dash board metal frame so pull that off and unplug..i THINK lol.
    sorry memory is pretty dull =="
    VS 304 Ute
    Oct 2008
    Yes there is a plug. Dont pull everything out!!
    Its under the dash so you have to remove the panel covering the fuses, in my car its a green plug in a black one (i think) just trace the wires from the door grommit to the car and its easy enough to find. Will save you alot of hassle.
    Good Luck
    Morton's Avatar
    Fairstar the Funship
    May 2006
    There should be a rubber grommet on the door, and one on the car. Take both off, and follow the wires back as far as you can. One of the two sides will have a plug
    The 1972 HQ Kingswood
    VU II SS
    Mar 2006
    yeah i had a quick look under the dash although was in a pretty angry mood at the time so just left it till i could do it properly today, hopefully i can find the plug easily, ill just have to swap over my locks to the new door then when i put it on
  1. Removing drivers window?
    By Malus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2007, 09:36 AM
  2. Removing Drivers Seat with AIR BAG
    By vz 914 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-03-2007, 08:58 AM
  3. Drivers Door Jam
    By Vanna in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-05-2006, 05:14 PM
  4. removing rear drivers door
    By BEAR18 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-11-2005, 05:37 PM
  5. Removing drivers seat
    By Sahab in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-04-2005, 10:03 PM
