Results 1 to 6 of 6
Thread: Help!!
    Vs
    Aug 2008
    Default Help!!
    need help guys
    was driving my 1993 vr wagon thursday night on the highway, and then my stero turned off then turned back on then there was a click sound, and a blue and white light under my dash then everthing died, i lost streeing had no brakes no lights anywere and no horn i could not start my car again and had to get it towed home. Just wondering if anyone might know what happend to my baby any idears would be great.
    Thanks
    None
    Aug 2005
    Adelaide, SA
    have you checked the battery to see if its flat? fuses? by the sounds of blue and white light maybe something shorted???
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    sounds like a blown fuse to me...
    check all the fuses and hope you havent fried your ecu!
    one cause could be shorting behind the stereo if you did a bodgie job wiring the H/U
    Phoenix21's Avatar
    Phoenix21 is offline Donating Member
    93 VR, 97 VT, 95 Statesman
    Feb 2006
    Crime bourne, Vic :P
    yer just check basics first battery, alternator, that flash under the dash would of been more then likly a fuse probably and then go from there
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, sounds like a big short has caused a fuse to go up in smoke. I'd be less worried about finding the fuse, and more worried about what caused it to blow in the first place Sounds like a pretty major wiring issue!
    Start with the things you have worked on most recently, and work back from there.
    The 1972 HQ Kingswood
    vr ute
    Sep 2008
    i think ozzie has hit the nail on the head with the radio. Had this once when a wire from the radio was left uncovered. Just takes a bump in the road for the wire to arch out on some metal and pop goes your fuses - good luck with the ecu.
