Went to go to the supermarket thismorning and i noticed the car was Real Sluggish. and when i got off the accel it was under brake load and would come to a halt very quickly.
i limped it home and it seems that the brakes are half locked on.. anyone ever come across this problem and anyone know where to start looking for the problem.
the wagon has ABS and had the brakes (discs and pads) done 7000km ago before i brought it.
my missus drove it 3 days ago and noticed the same issue and the brake light was locked on. then it came right and didnt do it again, done bout 40k since that and then thismoring it done it.....
bout all the info iv got.. bout to go do some investigationing!
m3taL... for what its worth...
http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
My Ride
88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
Turbo Manifolds and Plumbing Near completion!
Family Ride:
2007 Kia Grand Carnival Lux Model
Could be a sized caliper also are there any noises/vibrations coming from the breaking system?
I do all my own stunts....
sounds like a seized caliper to me too. Jack it up and see which wheel wont spin freely, and check it out for issues.
well i brought it home thismorning with it all locked on and swapped cars to go to work.
just took it for a drive and nothing wrong, done 40k, plenty of hard brakeing took it out on the highway upto 100k and braked hevily, and nothing wrong... seems to be another commodore intermittant problem... will just have to keep an eye on it.
Does anyone know if the ABS actually has an electronic Actuator in it? or is it only activated when the pedal is pressed? thinkin may be an abs fault...
if it was a Seized Caliper how do i fix this? Grease the slides??
My Ride
Family Ride:
Depends it could be simple as that or it might be the caliper piston once you have the caliper off you should be able to inspect it signs of surface rust etc on the slides or the piston its self.If it is a abs fault the dash abs light should light up on the dash and stay on well that's in japas sorry new to Holdensif it was a Seized Caliper how do i fix this? Grease the slides??but some one will confirm this please....
dont know much about abs but could there be a case where something small enough in the fluid keeps getting stuck in a particular hole then gets freed by pressure then recirculates?
The ABS OFF light may mean there is a sensor problem.
Try bridging Terminal 5 (black wire) and Terminal 12 (blue/black wire) on the connector under dash. The codes should spit out with the abs light (not the engine light like when you normally check for codes) .
Post back what codes you get and I'll let you know what it is...
Just can't be bothered typing all of them out atm lol.
Good Luck.
I very much doubt its the abs, it will only ever actuate if it detects wheel lockup, besides that its a dead unit until it gets signal. You will aslo hear and feel it whe it works. Also what you described is like brake drag, abs actually makes your calipers release not bite on. I'd be looking at your calipers still.
hey just got back from trackin all around the joint, no problems except for my missus said it sometimes seems to pull to the right.. checked ABS Codes and only code 12. i guess thats Normal Operation.
going to flush the brake system tomorrow and grease all the slides and stuff. throw a new set of pads under it just cos iv got them off. will be paying plenty of attn to right hand side brakes.
will keep posted
My Ride
Family Ride:
Yep, a bleed, grease and pads will do wonders! Make sure you use high temp grease when doing the slides...rubber grease is a good one...
hello my vr series 2 95 model executive has the same problom only mine di it every morning but i also get a steering wheel wobble with it some times..I can most times over come this by tapping the brake peddal a few times but it can still happen in the same day.I have jacked up the commodore in the morning and could not move my front left wheel at all.I have not checked the right one yet.My brake pads are good and i do not have abs so this is not a abs fault.I am gonna bleed the brakes and if that doesnt do the job i was gonna replace the front discs then inspect brake lines although the caliper could and proberly should be the first place of inspection.
thaks ill give that a go
a good one to check is the master clynder mine has been doin it alot. 1st noticd it at night and the brake light was hard on, looked at work (yay working for holden now) and didn't have a trouble shooting for it but then speaking to one of the older guys, was told to check for leaks at master clynder and i am about to rebuild it as it is 1/4 the price then replacing the whole thing... but ill also be checking the callipers/sliders, best lube sliders with sumthing like cooper coat(sticks like **** to a blanket) but works great as it heats up the better the sliding capabilities is, and i swear by it
