I know that it is left treaded but when i asked the guy at sprints he told me it was right treaded so following his instructions i completely broke where the tension pulley bolts into....
Does anyone have the instructions on how to replace the whole tension arm as i cant find my manual.....
any help will be greatful!
Menzy
1993 RED VR V6 Commodore: VY Front & Rear Black Leather Seats, Black Carpet, Custom Black interior, Whiteline Superlow Suspension Package, VT Front Brake Upgrade Kit, 2 1/2" Exuast, Sports Steering wheel, 17x8" ROH Adrenalins, Supercharged V6 Air intake, K&N Air Filter, 70mm Throttle Body, Custom Chip, Toughened T700 Stage 2 Shift-kitted Trans, after market trans cooler, Pioneer 9450 Head Deck with 6" in front and 6x9" in rear 2 Pioneer 12" Subs, 1000W Pioneer Digital amp, 2 Pioneer 300W Amps
im guessing you stuffed the bolt holding it in? get a set of reverse thread easy outs and rip it out, im not sure how to do the rest
No the bolt is fine but where it bolts into just shattered.
thats a complete tensioner arm, i did this myself, stripped it, and had to replace it. its not too hard, just need to remove the alt, and some other bits and pieces, cant remember all thats connected, buts its pretty simple, look at wats connected, and remove accordingly
remove alternator,
disconnect heater hoses leading out of the assembly
loosen the 3 bolts that hold the assembly on
remove the inner pipe where the heater hose was connected
remove the assembly and replace
word of warning when I replaced mine I had to redo it like 5 times because the damn heater connection kept leaking, I would suggest new O rings in there and some gasket seal
