Results 1 to 3 of 3
Thread: VR Power Window Motor
    VY SS
    Nov 2006
    Earth
    Default VR Power Window Motor
    Apparently Ive encountered a very common problem with my VR, the front passenger side window motor has shat itself, ive checked the switches and checked the circuit to the motor itself and everything is fine so that points to the motor itself not working properly.
    Im just wondering what im looking at to buy a new setup for it and whats involved in changing it
    Sleepy LS1
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    theres a how to in the how-to section on installing power windows, great guide on installing and can be used as a replacement guide. pretty simple to replace, just takes a lil time and patience
    u'll need to chase down a window reg, ur best be is wreckers, ebay, i dont believe holden have them anymore, but wont hurt to call.
    VY SS
    Nov 2006
    Earth
    ok i have an update........
    ive got my hands on another window regulator and pulled my door trim off, so i thought id test the power window setup that was in it already before i went drilling it out and without the loom plugged in it works!?!?! So now ive tested the loom back to the switch and the test light activates when it is unplugged from the motor but the second the loom is plugged in the circuit dies, so what im after is a wiring diagram to find the relay that activates it
    Sleepy LS1
  1. wtb - drivers door electric window motor
    By stocky in forum Swap / Wanted to Buy / Trade
    Last Post: 03-09-2008, 11:08 PM
  2. Power Window Up
    By AdamAnt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2008, 03:55 PM
  3. help! power Window goes down but not up
    By vncalais01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2007, 02:10 PM
  4. Rear Door Power Window Motor
    By Gr33ny in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-08-2005, 10:44 AM
  5. buying passengers side rear electric window motor
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2005, 12:36 PM
