Does any one have a method for sprucing up those black faded rear quarter window rubber linings?
managed to pick up a complete set of chrome calais window lining for my VS but the rear quarter window rubbers are looking all faded and what not.
Just asking if any has attempted to give it a fresh lick of black, if so whats involved in prep work and what paint should i use?
I did a howto a while back on them.
I used rollbar and chassi paint then, but recently ive been using black vinyl dye and plastic parts paint. very good results, weather tests so far indicate it will last well.
Best bet for prep would be to rub it all back a a bit with 600 grit wet n dry with soapy water, prepsol it, fill out those pitted areas, rub those back, prepsol again, adhesion promoter, and then the vinyl dye.
unfortunatly painting is the only way to do them properly without replacing them with new ones.
lol dannyboy, i remember seeing a how-to a while ago, tried looking for it in the how -to section
...err i couldnt find it =/ lol
Thats cause the Mods never moved it out of this section (hint, hint move it some time guys) the link is in this post as it also come up about a month ago here it is...
How to on painting faded/furry window surrounds????
the vinyl dye/plastic parts paint is perfect for it mate, goes on easy, it's got a good visco and it's not full gloss.
a few nice easy coats and you'll be right.
did anyone happen to find out how much they were brand new?
