Results 1 to 7 of 7
Thread: when adjusting idle speed...do i disconnect the TPS??
    UN4TOLDVRSS is offline un4toldvrss
    VR SS
    Feb 2007
    Default when adjusting idle speed...do i disconnect the TPS??
    As above....i have heard you need to disconnect the TPS??True or false??
    VX SS M6
    Jun 2005
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    false. you need to diconnect the battery or pull the fusible link for the engine managment (for a minimum of 10seconds) to reset the ecu.
    Body by Holden, Soul by Brock
    the Legend will live forever
    VR
    May 2008
    oh ho ... my dad took it upon himself to change my idle speed the other day. He just tinkered with the screw under the throttle-cable. Didnt disconnect the battery or fuse or anything. Now my cars idleing at 200 rpm, after starting at 1000.
    JJ's VR's Avatar
    JJ's VR is offline VRHLDN
    VR 3.8lt Supercharged 163.8kW & VS sII HSV Senator
    May 2006
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    tell your dad to maybe leave the commo alone, do a search on "reset idle" or similar, ive heard for the ecotec that resetting the ECU via the disconnect 20 amp engine fuse and attempt to start the car method, and then reinstalling the fuse, starting the car and holding it at 3 grand for 8 seconds, just what ive heard, anyone else heard that?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    ^^ Thats right, as Dannyboy said, but it sounds like Joe's dad has adjusted the base idle speed screw. This is not a wise thing to do. Joe, if you can work out the position the screw was before he adjusted it put it back where it was, then reset the IAC and ECU by removing the fuse. The IAC automatically adjusts idle speed by adjusting the amount of air flowing to the engine at idle. If it has a problem you should get a fault code.
  1. idle speed on s/1 VN V6
    By speednut in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-05-2008, 04:52 AM
  2. VN V6 Idle speed?
    By IvegotaCommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-01-2008, 09:41 AM
  3. Varying Idle speed.
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2007, 12:06 PM
  4. Idle Speed?
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-10-2005, 09:50 PM
  5. Idle speed
    By iamwellsie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-05-2005, 05:46 PM
