Results 1 to 2 of 2
Thread: Inside hazard light broken
    VS Standard
    Oct 2008
    Default Inside hazard light broken
    Hi
    im new
    my hazard light inside my car is broken therefore i cant indicate anymore
    i had removed my dash earlier and when i put it back on it worked then went for a drive and came back pulled it out then put it back on and now i cant indicate
    is there a way i can bypass this??
    or should i just go to u-pull-it and get a replacement would it be safer to??
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Is the indicator not working or the hazard lights - your post doesn't exactly say.
  1. Broken Hazard Light & Demister electronics
    By the_negro_puppy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2012, 10:21 PM
  2. How to bypass the hazard light switch (temp rewiring)?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2011, 05:17 PM
  3. Upgrade inside high mount brake light to LED?
    By holdenrules in forum Electrical Wiring / Questions
    Last Post: 25-08-2006, 12:52 AM
  4. Installing another light inside
    By Mr_Slim in forum Electrical Wiring / Questions
    Last Post: 06-09-2005, 04:54 PM
  5. Hazard Light Button - Flashes
    By Sammy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-07-2005, 03:36 PM
