ive bought and installed a whiteline adjustable panhard on my vs commodore and was shocked when the bush that goes on the axle side the hole in the bush was just a little bit bigger than the pin it goes on so its not a snug fit, would this be a bad thing cause if it i still have the nolathane bushes off my old bar that fitted perfect so would it be possible to cut out the whiteline bushes and put in the nolathane ones?
thats a little weird... did you get the correct panhard bar? like maybe they're different from vr-vs or something, cos its supposed to be a very snug fit otherwise it wont do its job. they even provide lube to help if im not mistaken? i had a nolathane one on my other vs ute and it worked a treat and went on perfectly first time. hopefully someone with whiteline experience can help
--APOC--
well the part number that came with it was kpr002x and that matches whats on the whiteline website maybe they put a wrong bush in it but im not sure i might have to give whiteline a call or something
If the nolathane one will fit just swap them over...See how you go. No halm in trying it.
yeah but the whiteline bush is pressed in so i might have to take it to a suspension place to take it out
see what whiteline say 1st they may have an answer 4 you question or they may have put the wrong part in the box and its an honest mistake
but dont go wreaking new products with out chatting to them k
