Results 1 to 6 of 6
Thread: Exhaust noisy
    VS commadore V6
    Mar 2007
    Default Exhaust noisy
    Hi all, my exhaust is the original standard one on it since i bought the car when almost brand new, but lately the exhaust is sounding louder, i don't know much about exhausts but i have had good look underneath her and the pipes look ok with no leaks and as far as i could see the muflers have no holes in them either, the louder noise is only coming out of the end of the exhaust pipe, so i am guessing that one or more of the muflers are rat ****, but which one i am not sure of as i don't know how to test them, is there are way of testing them ?
    I intend to go to an exhaust shop tommorow and get their evaluation & price but like to have a little knowledge beforehand in case i cop someone looking for extra work that possibly it doesn't really need.
    Appreciate for any suggestions
    Rony
    VS Maloo
    Jan 2006
    Hawkesbury
    just tell them your gettin a few opinions and quotes before making a decision. not sure wat it could be, hope someone else on here does...
    --APOC--
    VS commadore V6
    Mar 2007
    96 VS & 5spd VT 5.0L VX Clubsport lookalike
    Jun 2008
    Port Macquarie/Newcastle, NSW
    Its probably the mufflers have had it... I recently replaced my stock exhaust and if u shook the mufflers it would sound like a rice shaker, the parts inside were farked As for the exhaust place, if they say that only one of the mufflers has had it e.g. the first one...make sure they dont charge you for the other muffler and piping after the diff as well...
    hopefully that helps a little bit
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    get under the car and make a fist and tap it if it makes a dull thudding sound its most likely not the muffler if it sounds hollow it is the muffler my vp did the same before i pulled the exhaust of all together turned out the baffles in the muffler had let go
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    VS commadore V6
    Mar 2007
    Thanks a lot guys, your been a great help, i will check it out in the morning.
    much appreciated
    Rony
  1. Noisy 3.8
    By Loupy31 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-04-2008, 12:39 PM
  2. Noisy Lifters
    By Lost_Pete in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2007, 06:45 PM
  3. Noisy Air Con
    By Zedlen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2005, 01:56 AM
  4. Noisy Muffler... I Think?
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2005, 11:38 PM
  5. trans noisy
    By vlcalais88 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-05-2005, 05:56 PM
