Results 1 to 3 of 3
Thread: vr engine light on on long trips
    vr berlina
    Aug 2008
    Default vr engine light on on long trips
    i just took my vr berlina for a 2 hour trip and for about the last half hour the engine light went on and started leaking a bit of water into the car. i had the climate control on the whole trip so was wondering if that impacted the water coming into the drivers side of the car? i stopped for a few hours to do some things and then travelled home, and same thing happened the light came on with about half an hour to go. i had been going 110 for the majority of the trip and there didnt seem to be any lagging or anything like that but when we got into city driving, the light was still on and the only thing that was a bit different was it was a bit jerking changing gears from 1st to 2nd. any ideas of what happened?
    vt equipe, vt exec, 97 wrx LE
    Sep 2008
    adelaide
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by vpcommo View Post
    Water in the cab could be a blocked A/C drain on under the heaterbox on the tranny hump. it's a buger to get to but if its blocked the condensation runs back into the car.
    As for the engine light the car should have some error codes stored in the ECU. You will need to use the paper clip in the diag plug under the glovebox to see what codes come out.
    There is a thread on this site on how to check for error codes if you've not done it before - just use the search function and you should find it easy enough.
    12 is all systems good.
    and 3 Dangerous non ABS VN's
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  3. Car smells like oil after long trips
    By coolvxss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2006, 09:37 PM
  4. Warning Light on long trips.
    By THEVSMOFO in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2006, 09:52 PM
  5. Oil light staying on long after engine is off.
    By brydog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2006, 06:23 PM
