Results 1 to 4 of 4
Thread: Vr statesman bcm
    94 VR Statesman
    Aug 2006
    Question Vr statesman bcm
    Hi there
    just tried changing over BCMS today from the original BCM (398)
    to a VS Statesman series II BCM (399) (And matching key head for the new bcm)the engine turned over but it wouldnt start with the VS BCM also the drivers window automatically went down and wouldnt go back up. when i pressed unlock on the key 1st time indicators flashed twice and nothing happend 2nd tim i pressed unlock it unlocked all of them rather than just the drivers door first. can anyone shed some light on this situtation is there anything else i need to swap over??
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    maybe different wiring set up, there is a reason other than the change of models for the change in numbers
    VR Caprice
    Dec 2005
    BCMs are different. with the VS 1 your windows are going down automattically due to the BCM. You have to bypass the BCM for the windows to work properly its not hard I will try and find the info, its on the other forum by the nut. Also if you use a VS BCM you need a VS ecu. I have a VR stato BCM around somewhere if I can find it you can have it cheap.
    Your statrting probs are due to the security.
    94 VR Statesman
    Aug 2006
    so what your saying is i need to get a vs ecu for this bcm to work?
  1. vq statesman with vs statesman front
    By Mazzone_Child in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2012, 02:39 PM
  2. VQ statesman
    By sxchsv in forum Car Audio
    Last Post: 24-02-2009, 11:58 PM
  3. vs statesman
    By reaper01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2008, 11:35 AM
  4. s/c vs Statesman or Vs v8 Statesman???
    By younggun in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2007, 09:31 AM
  5. vs on vr statesman
    By ssilent11 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2007, 11:32 PM
