Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: ecotec into my vr (problems Arrg)
    Phoenix21's Avatar
    Phoenix21 is offline Donating Member
    93 VR, 97 VT, 95 Statesman
    Feb 2006
    Crime bourne, Vic :P
    Default ecotec into my vr (problems Arrg)
    hey all
    ok my vr motor decided to blow up a couple of weeks ago i happen to get hold of a vs motor pritty cheap so i've now droped that into my car changed the ecu and the motor side of the wiring loom put every thing back together to day and tryed to start it and all it did was make a really loud clicking sound from the starter motor im going to try and change that tomorrow but im still not sure that will work my question is the side of the loom that connects to the battery would i have to change that im not to sure if thats the one that runs into the bcm cause when i turn the ignition on the only lights that come on the dash are the battery light and the handbrake light i think the oil light is spose to come on 2 anyways any help would be great
    96 VS & 5spd VT 5.0L VX Clubsport lookalike
    Jun 2008
    Port Macquarie/Newcastle, NSW
    Might not be it but when I had that clicking noise I just needed a new battery...
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    make sure the battery is fully charged and or in working condition as said
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I'm pretty sure he tried jumping it from another car a few times, and with no better results.
    Unrelated to the starting issue:
    1) Does anyone know if the BCM changed from VR to VS?
    2) Would a VR BCM work with a VS ECU, given that the entire power side of the loom (relays, fuses, dash wiring) is still a VR loom?
    Basically at the moment, it's an Ecotec motor, Ecotec ECU, Ecotec engine loom, but VR Buick BCM and VR Buick power loom.
    The 1972 HQ Kingswood
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    look for an earth thats not connected to the body properly and check the charge of the battery for free at a battery shop/fitter if you dont have a multimeter. Im guessing it was the same battery when the motor blew up? how long was it sitting for? a battery that is DEAD flat will not charge (or hold a charge) whilst running/starting.
    Does the fuel pump prime etc??
    304 Calais
    Aug 2007
    Up your mum
    it helps to read properly first (need another coffee) if you dont have the engine warning light etc on the dash and only handbrake and battery then id say is a wiring issue (or bcm) BUT, the motor shouldnt crank with an inncorrect bcm so im guessing you changed that?
    Morton's Avatar
    May 2006
    Quote Originally Posted by vnv8driver View Post
    Well that's the funny thing, the battery ISN'T dead flat. Yes, it's the same one that the car died with, and it's been sitting in there for about three weeks, but it's got enough charge left such that the headlights, radio, etc all work. I know that doesn't indicate enough charge necessarily to crank a motor, but it's usually enough charge to turn over with a jump start.
    Does the fuel pump prime? That's a good question We'll see what he has to say.
    lol, I could use another coffee myself. I was thinking a wiring or BCM issue aswell, and came to the same conclusion as you - if the signal is getting as far as the starter and making it click, then the BCM can't be wrong...
    but just to confirm - it is NOT an ecotec (VS) bcm in there, it's the VR bcm. But the car is running a VS ecotec computer and engine loom. That is to say, the passenger side loom that runs to injectors, sensors, etc... not the power loom, which runs to fuses, relays, starter motor, etc. out of the driver's side.
    304 Calais
    Aug 2007
    Up your mum
    fark knows morty... was it being jumped by a battery sitting on the floor or a running car?
    Also if it was a bit flat, keep it connected to a running motor for a few minutes with the donor battery car held at a fast idle.
    Morton's Avatar
    May 2006
    I'm fairly certain it was a running car. I may have to drag my VQ down there and try jumping his car from mine. Off the top of my head, I think he was trying to jump it from a Magna.
    I've had experiences in the past, where a VN V6 wouldn't jump from another VP V6, but it jumped just fine from a V8 Land Rover using the same set of leads
    Morton's Avatar
    May 2006
    Okay, progress:
    1) Engine is turning over
    2) It has spark
    3) It has fuel pressure
    BUT
    It does NOT have an injector pulse.
    He's trying to run an error code check right now, but the engine light isn't working
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Chances are being a VR 93 it would have a TDM. I think your problem is something there.
    You may need the VATS wiped in the ECU.
    Maybe Dr Bob can help if he see's this thread.
    Phoenix21's Avatar
    Feb 2006
    VR Caprice
    Dec 2005
    There are some differences in the BCMs. Also if the motor came from a calais or stato you might be having security issues. Try a VS BCM the same as the car the motor came out of.
    Phoenix21's Avatar
    Feb 2006
    i need another keyhead that im still thinking it could be somthing with the pcm /ecu cause ive got spark but no injectors
  15. #15
    VR Caprice
    Dec 2005
    The security feature will do that it turns off the injector pulse but still gives power to the starter motor.
  16. #16
    Phoenix21's Avatar
    Feb 2006
  17. #17
    VR Caprice
    Dec 2005
    You need to get a BCM and ECU that talk. If the ecu you got was in a calias or stato then you need a high BCM. you need to match the ECU and BCM with the new motor. Sorry if this is dutch but I backed the winner of the cup and have celebrated
  18. #18
    Phoenix21's Avatar
    Feb 2006
    would it matter if one was off a vs (ecu) and one was off a vr (BCM) since i think
    there the same anyways
  19. #19
    VR Caprice
    Dec 2005
    They have to be from the same model as there are differences between the VR and VS
  20. #20
    vr berlina
    Oct 2007
    Sunny Coast
    Did u get it going Phenoix? Would like to know what the out come was as i am doing the same conver.
    All GO
  21. #21
    vr berlina v6
    May 2010
    Hi, Iam doing the same conversion too, would like to know as well, had my ecu tuned but still no start any help would be very gateful
  22. #22
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i got your PM so did they turn the security off in the ecu for you
  23. #23
    vr berlina v6
    May 2010
    в∞ѕтεכ √&
    Jul 2008
    NZ
    nope dont need a bcm at all when the security is off.on the ecu plugs make sure you have constant 12v on pins B8 & A8 which are red and black should have power all the time.and pins E9 & A4 which are pink should have 12v only when ignition is on check that is happening and get back to me with results
  25. #25
    vr berlina v6
    May 2010
    ok the B8 & A8 have no power at all and A4 has power when thw ignition is on but E9 has no power at all ?
  1. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  2. ecotec to ls1 swap, what problems will i have?
    By fluxxx in forum General Discussion
    Last Post: 04-05-2007, 01:21 PM
  3. Plenum Problems (ecotec)
    By andyman in forum General
    Last Post: 26-03-2007, 05:41 PM
  4. shocker nut keeps gettin loose.. arrg help
    By beefcream in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2006, 07:50 AM
  5. Ecotec Problems....
    By Gobbles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2004, 04:24 PM
