I know the brakes on the six`s were 296x29(?) and the V8`s were 330mmx(?) so will the LS1 one s fit on a VR SS, is it the 296 everyone upgrades to?
and was there any diff in caliper size betwwen the 6 and the 8.
Helpski, I want to do the upgrade but need to know what will fit and what won`t.
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
Holden VT, X, Y front and rear brakes are identical for V6 and V8. HSV fitted larger brakes. The VT 296mm rotors and twin piston calipers will fit onto your VR easily with 15in rims but if you go for the 330mm fronts I think you need 17in rims minimum. Regarding the 296mm and 330mm calipers the only difference I've noticed is that the slider is bigger for the 330mm rotors and the rest is identical and for the larger brakes you also need brackets to further extend the caliper to fit the 330mm rotors.
VT-VZ HSV 330 discs are 32mm thick whilst VT-VZ std 296mm and VS 330mm discs are 28mm thick.
There have been some kits on ebay that use the std VT caliper with aluminium adapting bracket over VS style 330x28 discs.
DBA do 330x28's for both the VS 70mm and VT 71.5mm centre bores.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
Thanks guys, nice thorough info that I need, I`m doing a bunch of projects at the moment (the bug has bitten) like body kit, interior uphostery, so yer, she is going to be one sweet BT1.
