Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Thread: Why cant i get it LOW!!! (VS clubby)
    VS CLUBSPORT II
    Aug 2008
    Perth, West Coast
    Default Why cant i get it LOW!!! (VS clubby)
    ok, so im runnin a VS clubby with fresh 20'inch chrome and brand new coilovers in the front. this is all good and well.
    my problem lies in the back end. i have the lowest springs on the market, BMW 6series lowered (these are the lowest springs available, lower than all kings springs etc) or something like that and monroe GT shocks and it just wont sit low.
    it sits at the top of the 20 inch tyre and it should be tucking the rim by now!!
    could something be holding it up or do i need to get the spring even more compressed?
    please.. somebody save me any more headaches and money!! haha
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    LightningVP is offline Donating Member
    None
    Sep 2008
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    it could prob be that ur on bump stops, jack the car up take out the bump stops, cut them completely off and then that will prob help with ur height issue, if its still sitting high, go and get them compresses a bit more and that may help...but my bet is with bump stops, they are useless anyway lol
    hope ive helpd
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Jack her up, remove the springs, and let it back down gently with the jack. See if anything is doing silly things when you begin to lower PAST the point it would sit at with your BMW springs
    The 1972 HQ Kingswood
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Could be the new shockies that near wearing in. Pop the boot stand on the back and push down and up a few times and see if it makes any difference.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    Quote Originally Posted by VRSLT323 View Post
    hope ive helpd
    you can get nolathane spring rubbers that are thinner than normal
    VS CLUBSPORT II
    Aug 2008
    Perth, West Coast
    man, thanks heaps for all the feedback, i cant believe how fast you guys are gettin back to me..
    hope ive helpd
    firstly, its not sittin anywhere near the bumpstops, probably like, the bumpstops are prob like 1.5-2 inches apart still!!! and i got told with these springs it should sit close to them!!!!
    MORTON, so you mean drop it down slow with the springs out all together? where should i be looking mate? any ideas? is it possible that something is holdin it up? these springs are meant to put it on its A#$!!
    VS CLUBSPORT II
    Aug 2008
    Perth, West Coast
    Quote Originally Posted by Zuicider View Post
    where from man? every half inch matters haha!!
    Chirpstr's Avatar
    Sep 2007
    Zuicider you talking about the front? Or rear? the rear are completely different...they sit above the diff. Or maybe your talking spring insulators for the rear...
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by emortalwa View Post
    Yea, remove the springs, and lower the car carefully, below where its sitting now. u'll soon find out with its ur shocks or something else weird goin on.
    you can always remove the bottom bolt on your shocks so its only the springs holding the weight of your car, and again, lower carfully, see where it sits..
    what shocks you have under the car? by the sounds of it, u'll need shortened shocks, and i mean shorter than your standard shortened shocks.
    Morton's Avatar
    May 2006
    Your car is sitting 1.5-2 inches from the bumpstops? That's pretty low in my book
    I don't think you have any issues. Tucking rim is hard work with VS wheel arches. If you want to ride any lower than that, why not remove the springs altogether, find the height your shocks would sit at when on bumpstops, and weld them solid?
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    i wouldn't mind finding a part number for this aswell if anyone has one?
    VX SS M6
    Jun 2005
    mine was sitting on the bumpstops so i cut 3/4 of them off, also got thinner spring seat rubbers. mines live axel though.
    maybe your shocks arent short enough? leave them in and drive around for a couple of days and see if it settles. also show us some pics.
  15. #15
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Is it IRS?
    if so you may need to turn the springs around. Theres a high and low part on the ends of the springs and they might not be sitting snug
  16. #16
    Aug 2005
    i have same problem i rang king springs and asked wtf i have bought sssl's for rear and it doesnt even tuck tire on 17 international and he said that vs's dont have a consistant lowering rate that they were poorly made and that some will drop some wont and thats the end of the story.....dont no if thats true but either way i feel your pain ive been through 4 sets of rear springs and none have done the job yet
  17. #17
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    new shocks and springs will make the car sit high for a week or 2, usually take 2 weeks for springs to fully sage and about the same for shock absorbers.
  18. #18
    howepower's Avatar
    howepower is offline Donating Member
    vc commodore sl
    Nov 2008
    KIELOR DOWNS
    Quote Originally Posted by Morton View Post
    excellent suggestion it is the only way you will find out why it will not lower anymore
  19. #19
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
  20. #20
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Shocks will not bottom out before the bumpstops touch, but they will prevent the car from dropping as much as it should on an IRS. Don't ask me why, it just happens. Jack the car up a bit, undo the bottom shock bolt and let the car back down, you will find it will drop further. New shocks always lift the arse of an IRS rear end. Fitting shortened shocks may work but I don't think they will.
    Visit my Facebook page
  21. #21
    1994 VR Exec, 5.0L BT1
    Jan 2005
    Quote Originally Posted by Ozzie View Post
    Is it IRS?
    I put new springs in my IRS commy last weekend, I didn't notice any high/low sides to the spring. Is there neway to tell if I put them in the correct way?
  22. #22
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    One end of the spring has thicker coils, these go down.
  23. #23
    VR V6 5spd '93
    Nov 2006
    Southern NSW
    sorry to jack your thread mate, not really worth startin a new one thats nearly the same though.
    i've been having issues with my front end, i just got new kyb short stroke shocks with ultra low king springs, and it sits about half an inch above the 19 inch tyre. Had superlows with standard shocks and they seem to be exactly the same height as the ultra lows w/ short shocks.
    I've seen other vr/vs's pretty low in the front, i usto have my standard springs cut (with standard shocks) and it was just tucking tyre at the front which was good.
    Does anyone know how to have this same sort of setup with un-cut springs?
    I had a play around with an ultra spring today, just to see, i cut about 3/4 of a coil off it, (the first half doesnt really do anything cause it spring goes flat at the top an bottom) but now its too short and doesnt reach/put any pressure at all on the bearing/rubber strut top an the bearings just fall out.
    I am yet to try the standard and the modified ultra spring on the standard shock, maybe the seat is positioned a bit lower. Would be great to work something proper out here, i dont want cut springs at all.
    My mate has a vs v8 ute, with pedders springs and shocks, dont know how he's done it, but he'd honestly be tuckin a good half inch under his guards, no bullshit. This is why i am so determined to work out what i can do.
    Thanks for any advice.
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
  25. #25
    VR V6 5spd '93
    Nov 2006
    Southern NSW
    Ha, yeah, the back in tuckin nearly half the tyre, and the fronts got about 2cm tyre to guard clearance... looks like its about to take off.
  1. FS - WA VY2 Clubby
    By mar-d-mac in forum Vehicles For Sale
    Last Post: 10-05-2008, 10:08 PM
  2. my vz clubby R8
    By vp stroker in forum VY - VZ - WK - WL - V2
    Last Post: 03-12-2007, 08:37 PM
  3. W2S: VX clubby kit for VR/VS
    By KLR38L in forum Parts And Other Items For Sale
    Last Post: 28-02-2007, 03:34 PM
  4. VZ Clubby kit for VX
    By INSINR8R in forum General
    Last Post: 24-11-2005, 05:30 PM
  5. new vt-vx clubby
    By NVE_069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2005, 10:35 AM
