Results 1 to 8 of 8
Thread: Hard to start?
    ElDubya's Avatar
    ElDubya is offline Mad As A Meataxe
    1994 VR SS Sedan
    Jun 2005
    Default Hard to start?
    Hi all,
    Lately, my VR SS has become hard to start. I can turn the key to the start position, and sometimes it can take 5 seconds for it to start winding over. More often that not though, it only takes around 2 seconds.
    How can I fix this?
    The very existance of flamethrowers proves that sometime, somewhere, someone said to themselves, 'You know, I want to set those people over there on fire, but I'm just not close enough to do it.
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    ElDubya's Avatar
    1994 VR SS Sedan
    Jun 2005
    Okay. Up to page 15 of my search and still no definiteive answer that I can find? What's your next little pearl of wisdom, or should I just give up and post on another forum?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It's possible the battery in the key is going flat. Also check that it makes good contact where it goes into the ignition keyhole - it must make electrical contact.
    Maybe supply more info - like only difficult when hot etc plus any recent work done to engine/electrics......the more clues the better.
    ElDubya's Avatar
    1994 VR SS Sedan
    Jun 2005
    Thanks Hako. No recent mods, but I have noticed nearly all VR-VS I get in, the problem is evident in almost all of them to a certain degree.
    Some take a split second to start turning over, and some like mine can sometimes take up to 5 seconds. I am thinking of replacing the relay for the starter and see if that fixes anything. I will definitely try pushing the key into the ignition hard as I turn it and see if that does anything.
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by ElDubya View Post
    If you happen to find out what is causing the extended amount of time need of cranking over for your VR/VS please do share as my ute is the same and takes a little longer to crank then i would think is necessary. It seems with my VS Ute that if i crank it over before letting the fuel pump prime it starts quicker then after letting it prime? Any ideas?
    It is the fuel pump im hearing right?
    Also just to add i have a m8 with a VS that has a lot of kms and well it is way worse then mine lol
    Thanks
    Matt
    pr0n's Avatar
    pr0n is offline It's A Me ' MARIO '
    03 VY II S V6
    Dec 2006
    Gladstone
    my vp does the same thing, afters its just been started turn it off and turn it back on and it starts instantly, cold starts or even like 10 mins after you turn it off and it can take upto 5 seconds to start, trying to figure it out myself
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    ive had similar problem also.
    Ive tried 3 of my keys, and problem still there.
    key into ignition, turn key not start.
    put car into neutral, turn key, cars start fine.
    Im guessing the park gear sensor is up **** creek, and will go visit Mr Automatic on friday after work, to see if he is able to fix this poblem i have.
    My dad has also said that the ignition barrel could be on its way out, so that maybe your problem too.
    dont worry, il start a ride thread soon.
  1. VR hard to start
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 10:24 AM
  2. VP V6 Hard To Start - Help
    By oldfart in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2010, 05:39 PM
  3. Hard to start
    By Ross S in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2007, 04:51 PM
  4. hard 2 start
    By burnz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2005, 03:35 PM
  5. Hard to start
    By stheggie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2004, 02:30 PM
