Results 1 to 10 of 10
Thread: engine computer light keeps coming on
    Mar 2008
    Default engine computer light keeps coming on
    engine computer light keeps coming on in a 1995 vs v6
    have had 2 new oxy sensors ,crank,cam,dfi all replaced with new sensors
    stays on for between 1 and 15 mins
    any ideas
    running good
    7 snakes 4 kids 1 wife 1 ea falcon 1 vs dunny door
    vsiicalais's Avatar
    vsiicalais is offline Donating Member
    VEII Thunder SV6
    Aug 2007
    Warragul
    have u check for error codes, they do save for a few days so you can check them
    How To - Fix Reverse Lights For Free!
    http://forums.justcommodores.com.au/...commodore.html
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    As soon as the light comes on it logs a code. It is saved until it is cleared.
    These are the codes Just Commodores - For All Your Holden Commodore Needs
    And this is how to check them Checking error codes VR/VS (Revised)
    Visit my Facebook page
    Mar 2008
    code 12/48/63 came up
    but those sensors are new
    Mar 2008
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Clear the codes by disconnecting the battery for 10 seconds then go for a drive and see if the light comes on again. When you get back, just check the codes again.
    Mar 2008
    done that will go 4 a drive in morning to ****ed off to do it now lol
    Mar 2008
    have been driving ot around the compter light hasnt come on
    i undid all the sensor connections put back to gether then undid the battry for a couple of minutes had to reprogram both keys though only took a couple of minutes
    fingers crossed i fixed the problem might of been a couple of bad connections
    Mar 2008
    havent checked the codes will do in morning
    chromic's Avatar
    chromic is offline Donating Member
    VT V6 Sedan, VY SS sedan
    Nov 2005
    My light keeps coming on too after I replaced the low pressure hose on my power steering pump. I lost a lot of fluid doing that so it must have got on the sensors or something. I will check codes as well.
  1. Check engine light keeps coming on
    By chromic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2008, 08:58 PM
  2. Engine warning light keeps coming on how come ?
    By Ygoford in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2008, 03:08 PM
  3. Engine light coming on.
    By Nanos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2008, 07:30 PM
  4. Engine check light not coming on!!
    By bladerunnerkim in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2007, 11:03 PM
  5. Engine Light keeps coming on
    By Naughty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2006, 03:08 PM
