Results 1 to 8 of 8
Thread: replacing Low bcm with Lux bcm issues
    vsiicalais's Avatar
    vsiicalais is offline Donating Member
    VEII Thunder SV6
    Aug 2007
    Warragul
    Default replacing Low bcm with Lux bcm issues
    hey guys i just purchased a Lux BCM as i want to add a few of the functions that it has into my car, and my old bcm has fried some of its circuitry, anyway i went to fit the bcm but found i have a slight issue. there are not enough plugs in the car or maybe im not looking in the right area. anyone got any ideas on this? i have an executive.
    How To - Fix Reverse Lights For Free!
    http://forums.justcommodores.com.au/...commodore.html
    VX S2 Exec
    Sep 2008
    you will need the wiring loom for all the new features that the lux model supports, also the car keys for that BCM and then you will either need to change your key head to your keys or change the locks and ign barrel to suit
    vsiicalais's Avatar
    VEII Thunder SV6
    Aug 2007
    Warragul
    i have a calais wiring loom for the dash but cant find the extra plugs i need for the bcm, i have a keyhead that came with the bcm as well.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the bcms are completely different, you would need to change the complete dash wiring harness to get close to making it work
    vsiicalais's Avatar
    VEII Thunder SV6
    Aug 2007
    Warragul
    i am already running the level 3 dash cluster and instead of splicing wires into my original loom i just purchased a calais loom, all of that is fitted, but there are no loose plugs on it, is it a totally seperate loom again or what? i will get down to pick a part in a week or 2 but was hoping to get it fitted before then if possible. thanks
    VX S Pac
    Jul 2009
    Exclamation BCM Fault in VX Commodore
    I have been having a problem with my car lately. It's been getting harder to start each day. I had it tested at a garage and they said the BCM has logged a fault code and the BCM itself is at fault. They recommend I replace the BCM and the two keys. They said it would be around $1100.00 to fix it.
    Is there anything I can do first to try and fix it?
    Please help
    VR Caprice
    Dec 2005
    You are being ripped, $1100 for a BCM and 2 Keyheads is just ridiculas. You can get a BCM and key heads from most wreckers for under $150 and it is easy to fit.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by waveracer View Post
    Please help
    All I can say is don't go back to that garage. As already said, buy a second hand BCM or get a new one for less than have of what you were quoted.
    MY RIDE
  1. Help BCM issues
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2007, 02:20 AM
  2. VT issues
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-05-2007, 01:17 AM
  3. vk issues
    By Roman Hans in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-07-2006, 01:49 PM
  4. VL issues - please help
    By hobnog in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-03-2006, 08:54 PM
  5. issues
    By Garth in forum Site Feedback / Site Problems
    Last Post: 22-07-2005, 06:18 AM
