Results 1 to 19 of 19
Thread: Rear Muffler Inquiry
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Default Rear Muffler Inquiry
    My rear muffler in the VR wags has rusted out a fair bit, the question i wanted to ask was can i legally remove the rear muffler......leaving the pipe short or will i have to weld on a section to take it right to the rear of the car.
    Also, im assuming this will affect the sound of the car (stock exhaust) and fuel efficency?
    Any help is appreciated as always.
    VY SS
    Jun 2006
    Albany
    you can legally remove the rear muffler but you will have to extend the exhaust, the exhaust note might change a little bit but i think ur fuel economy will stay the same
    Phoenix21's Avatar
    Phoenix21 is offline Donating Member
    93 VR, 97 VT, 95 Statesman
    Feb 2006
    Crime bourne, Vic :P
    shouldn't affect the sound 2much and could improve fuel economy cause of less restriction
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    ahhh, cheers guys, wasnt too sure.......just didnt want to replace the muffler if i didnt have to
    Haydz's Avatar
    Haydz is offline Fasten your seatbelts
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    It will change the sound slightly when its hot. you might get a few crackles etc.. but not a whole lot..
    and yeah.. you should extend it but its often overlooked if your car isnt loud. they wont mind just make sure you cut the pipe after the diff and youll be fine
    VX II SS Ex Chaser V8
    Jul 2005
    VL SL Turbo
    Feb 2006
    Quote Originally Posted by ozengines View Post
    You want to extend it for sure or fill the cab with exhaust fumes.
    its not worth cutting it, unless u extend it, i got defected for having a cut exaust n it was an easy ticket to the pits
    safest way is to extent it, dosent realy change the sound i did it 2 my mates VS BT1
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Before this thread dies i was just wondering if anyone could help me out. I have a Holden VS Ute and well am looking at removing the rear muffler for a little more noise out of my whittle V6. My question though, is it legal/illegal to dump the exhaust under my ute before the diff as in this picture
    My car is no where near that low or anything but i was just wondering if this is or isn't legal and if anyone could link me to the law stating what it is? All i have been able to hear/read is it has to be dumped at least 30cm back from the last door which on a ute shouldn't be a problem?
    Any info is much appreciated
    Thanks
    Matt
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by jokerflingo View Post
    Thanks
    Matt
    not sure on legalities but DAM!! that car is low!!
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    I would like to know the law about this to.
    Right now ive just got mine dumped just before the full tank. All I have done was saw off the rear resinator as close to it as i could to remove it then left it. On a stock VN no one picked i didnt have a exhaust, altho now with SS rear there's more of a mould for it so you can notice But have had cops behind me for a while, had then pull me over, no word about it.
    Once they pulled me over when i had it off just after the FIRST muffler, with a fuel car of teenages and a red P they didnt say anything, i can tell you i was going very easy on the throttle leaving that!
    Quote Originally Posted by jas98 View Post
    lol, i bet theres some people in it (i mean alot), or its bagged.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    not sure if its legal i drought it would be, but i'm going to do that in the next month or so regardless, who's car is it?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by mischa View Post
    lol yeh one big guy:P
    Aug 2008
    Ok guys found a bit more info. Here is the car (Or should i say UTE) that i am talking about and i bet your all surprised :P Its NefariousLS1 car from the LS1 forums.
    What i would like help with though is this info on the SA Exhaust Laws. Can anyone help me translate this into something i would understand eg. Key Dot Points?
    Division 2—Exhaust systems
    148—Exhaust systems
    (1) The outlet of the exhaust system fitted to a motor vehicle (except a bus) must extend:
    (a) behind the back seat; and
    (b) at least 40 millimetres beyond the outermost joint of the floorpan that is not continuously welded or permanently sealed; and
    (c) to the edge of the vehicle, if:
    (i) the body of the vehicle is permanently enclosed; and
    (ii) the vehicle is not fitted with a vertical exhaust system; and
    (d) no further than the edge of the vehicle at its widest point.
    (2) The outlet must discharge the main exhaust flow to the air:
    (a) if the vehicle is fitted, or required under a law of this jurisdiction to be fitted,
    with an exhaust system with a vertical outlet pipe:
    (i) at an angle above the horizontal; and
    (ii) at least 150 millimetres above the cab of the vehicle; and
    (iii) rearwards or to the right of the vehicle; and
    (b) in any other case:
    (i) horizontally or at an angle of not over 45
    (ii) under 750 millimetres above ground level; and
    (iii) rearwards or to the right of the vehicle.
    What i would really like to know is if it is actually legal on my VS Ute to do what the owner has done in my first post? Because quite frankly i got no clue what that legislation means
    Any help on the above would be great
    Thanks
    Matt
    Sep 2008
  15. #15
    Aug 2008
    Quote Originally Posted by fuzzy2308 View Post
    can anyone tell me the pros and cons of this
    More free flowing with only one muffler so better performance/economy etc and it should be a nice sound all be a bit louder.
    Its conless :P
    Hopefully
    Matt
  16. #16
    Sep 2008
  17. #17
    Aug 2008
    cheers which part of the exhaust is the environmental thing?
    The CAT i presume you mean which is right after the headers/extractors and before the main muffler.
    Matt
  18. #18
    VL SL Turbo
    Feb 2006
    pretty sure anything before the diff is illegal, at least in sa dont know bout other states
  19. #19
    Aug 2008
    Quote Originally Posted by woodyotoad View Post
    I reckon thats true except on a ute which only has one door each side :P Well i hope thats how it is :P
  1. WTB-NSW-Rear seat and rear muffler (vr wagon)
    By chromic in forum Swap / Wanted to Buy / Trade
    Last Post: 20-10-2008, 10:44 PM
  2. Rear muffler
    By Burniehoon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2008, 05:14 PM
  3. vn rear muffler
    By anothervn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2008, 05:52 PM
  4. rear muffler or not
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2005, 03:16 PM
  5. rear muffler
    By mezza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-07-2005, 04:57 PM
