Results 1 to 6 of 6
Thread: install cd player plus park lights
    vs executive
    Nov 2008
    Default install cd player plus park lights
    hey i installed a jvc cd player to my car when i done so and put everything back together i found i had my park lights staying on even with out the key in the ignition i currently keep taking the radio fuse out so my battery wont go flat can anyone help?????????????
    VS Maloo
    Jan 2006
    Hawkesbury
    make sure you havent shorted out 2 wires behind the cd player, or cut any wires. id pull it out and tape up/cable tie any loose cables just to be safe
    --APOC--
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    ^^ agreed ^^
    you have obviously touched/joined, the wrong set of wires, as above, remove ur cd unit, check all wiring. i would almost run new wires for power and ground too.
    VS Maloo
    Jan 2006
    Hawkesbury
    running new wires would help... actually thats another thing... make sure your running your ground wire to the chassis of the car, dont try n find a neutral wire.
    --APOC--
    big m's Avatar
    big m is offline FIGJAM
    vslll v6 2000 olympic series ute, 1997 pajero 3.5l
    Sep 2006
    nsw
    hey i have jsut fixed a problem with a stereo i just installd in my gf sisters car and then i had NO parklights anyway after a long time of research and mucking about i relised that i had the earth running through the illumination wire so i earthed it to the chasis and ran the illumination wire through the acc and now all is good as for your problem i would say that you have your illumination wire bridged across your memory wire somewere find that and that should fix it
    Homer: "for once in my life someone is calling me sir without (your making a scene)"
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    ^ same thing happend to my mates patrol, installed cd player, kept blowing fuses and end result in no parkers, grounded earth to chasis, replaced the fuse and happy days..
    simple mistake, but can cause weird ass issues
  1. vt park lights
    By timdawes in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-07-2011, 08:47 PM
  2. Park lights
    By holdenmyk in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-02-2008, 05:13 AM
  3. cd player install help
    By ripper44 in forum Car Audio
    Last Post: 09-01-2008, 09:59 PM
  4. VT/VX CD Player install Q's
    By HoldenMad in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2006, 09:11 PM
  5. Cd Player Install
    By Sambo in forum Car Audio
    Last Post: 06-02-2004, 09:38 PM
