Has anyone bagges a VS. Im looking at a bag kit on ebay for a solid axle VS. Couldnt see it too hard installing the bags. How much work and how hard is it to install the compressor and airlines etc. Im guessing the compressor is mounted in the boot.??? Is there much noise in the cabin from the compressor
not to hard if you know what your doing on the wiring and airline side of things, not something that you want a dodgy job done on man, the compressor makes a fair bit of sound it can get quite anoying, wast of money imo just dump it and be done with it![]()
MY RIDE - BAGGED CAPRICE
http://forums.justcommodores.com.au/...s-caprice.html
the larger the tank the less often the compressor will have to stop start for also.
you can just run the bags without a compressor as well and just lower/raise them at the servo with the air line there
I sthink it ends up costing around 2.5k once you have it all setup for the set of 4 bags compressor and tank..
+1 to the above just sack it
