Results 1 to 5 of 5
Thread: VR front end grinding noise
    VR Berlina
    Feb 2005
    bendigo, vic
    Default VR front end grinding noise
    Hey guys. i got a 94 vr v6 which has been making a horrible grinding noise when i take off in first. i thought it may be broken engine mounts causing the engine to tip over, forcing the exhaust into the body, but checked it and its not that. i replaced the front wheel bearings, and all the bushes and shocks. also checked the gear box crossmember which is tight.... so im stumped as to what this noise can be. it only happens when giving it a bit of power..... anyone got an idea what it could be?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check your exhaust from the front to the back....also try to move the rear end of the transmission side to side - if it moves the mount is shot allowing the engine to rub against the body 'somewhere'. It is an auto?
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    when you nail it, you will feel the motor jumping up and down rapidly, but on a normal takeoff wont be noticeable, if it is the engine mounts.
    VR Berlina
    Feb 2005
    bendigo, vic
    exhaust has been checked all the way. engine doesnt shift much under load either. engine mounts were replaced 6 months ago anyway. tested it the other day by loading it up and releasing.. its not moving. the gear box wont budge either so im lost its driving me nuts. been to 2 suspension specialists and everything they suggested was to no avail...
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    Check the ac compressor clutch/bearings. (unlikely).
    Check all the other pulleys by taking the belt off and spinning it.
  1. grinding noise....:(
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2009, 12:15 AM
  2. grinding noise
    By ned in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-02-2009, 11:06 AM
  3. grinding noise under front left
    By DannyboyDS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2008, 10:02 PM
  4. bad Grinding noise
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2008, 07:51 PM
  5. Front wheel grinding noise
    By clintonhadenham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-08-2005, 06:21 PM
