Results 1 to 4 of 4
Thread: which petrol tanks fit
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    Default which petrol tanks fit
    Hi, my brother ran over something and put a hole in my dads v6 vr sedan petty tank. Which fuel tanks fit? I can get a vn or vp one pretty easy but a vr/vs one is a bit hard to find here.
    Just wondering if the tank from a vn/vp will fit.
    Cheers Shane
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    yes it will fit, but the breather holes are different.
    dont go vn/p u'll have problems, i did, and had a fair bit of fuel coming out the carbon canister, was lucky enough nothing caught fire.
    vr/s tanks only have 1 breather pipe and a return pipe, the vn/ps have 2 breathers and a return or something along those lines. one pipe is about 15mm and the other is like 5mm. thats what your after
    maginoodle's Avatar
    Apr 2006
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    if you get the chance, to be 100% sure, u can always loosen the straps and check out the hose connections on the top of the tank, using a jack to lower the tank just a little bit, and you wont need to disconnect any pipes either.
  1. Getting LPG tanks tested.
    By DANNY8 in forum General
    Last Post: 19-10-2008, 10:44 PM
  2. drop tanks for vs
    By jase_vs_comma in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2008, 02:15 PM
  3. fuel tanks
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 11:51 PM
  4. fuel tanks
    By drewboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2006, 05:23 PM
  5. Drop Tanks...
    By VP2NV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2005, 10:27 PM
