Results 1 to 10 of 10
Thread: **vs clubby manuel gearbox issue**
    vs clubsport
    Aug 2008
    Exclamation **vs clubby manuel gearbox issue**
    hey guys ive noticed it gets tight getting into 1st gear stopt wat could this be my gearbox is on its way ?? or another issue cheers guys when i select gears n off n on the clutch the select smooth once i start driving again
    it tights back up in 1st?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    You may have to be a little more specific.
    Are you talking about upshifting or downshifting into 1st? I didn't understand anything else to be honest
    The 1972 HQ Kingswood
    vs clubsport
    Aug 2008
    ok say ur stopt at the lights and u put foot clutch the engage it in 1st gear dats wat i mean its tight then when u push hard enuff locks in gear
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    sounds like nothing man, just get the manual serviced. and see if it is still there
    vs clubsport
    Aug 2008
    i got the manuel serviced when i 1st bought the car and ive nearly had it for 1 yr
    yer i think il do dat
    how much for a trans service
    redcv6's Avatar
    Aug 2006
    Ringwood
    vs clubsport
    Aug 2008
    95 manual vs s pac
    Jul 2008
    sydney NSW
    my vs does this every now and then. try with the clutch pushed in putting it into second then first.you see putting it into second open's the gate so you can put it into first so i have been told by a mechanic.
    Haydz's Avatar
    Haydz is offline Fasten your seatbelts
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    vs clubsport
    Aug 2008
    when do u usually do a maneul transmission service the 1st 1 i did was in 2006 i heard it last up 50,000kms before due to next trans service if this is true then its got nothing to do with my service
    i was think could it be the rubber surronding round the gear stick underneath the console ??
  1. vs clubby gearbox problem
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2008, 12:29 AM
  2. vs clubby lag top end issue
    Last Post: 31-10-2008, 06:34 PM
  3. Vs clubby irs diff knock issue
    Last Post: 19-10-2008, 04:40 PM
  4. fuel issue vs clubby
    Last Post: 16-10-2008, 04:17 PM
  5. Gearbox Issue!
    By Emackulation in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 01:16 PM
