Results 1 to 6 of 6
Thread: forgot my Haynes manual need some tourqe settings
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Default forgot my Haynes manual need some tourqe settings
    Sorry to hassel everyone
    Me and a mate are doing my inlet manifold gasket today, he is traveling a fair distance to help me and I forgot to bring my Haynes manual, which also is a fair distance away now
    If anyone can help me out by posting up the tourqe settings and maybe even the tightening sequence for the inlet manifold and the plenum for VS v6 L36 (Ecotec) i'd be forever gratefull.
    Thank you in advance.
    VR Caprice
    Dec 2005
    VS Berlina
    Feb 2007
    Thanks Neil, that info was perfect.
    The job is all done, I now have a slight miss at idle no error codes as of yet, so i'll try to remove and refit the plenum only and see how that goes.
    I didn't use any silicone on the inlet manifold gaskets as I was told not to, however I did use some on the valley gaskets and the inlet manifold bolts, i'm not sure if it was oxy sensor safe, could this be the issue? would it cause an issue without logging a code?
    chromic's Avatar
    chromic is offline Donating Member
    VT V6 Sedan, VY SS sedan
    Nov 2005
    I used permatex (sensor safe) on my inlet manifold gaskets when I replaced them last month. Have you plugged in all the vacuum hoses?
    My car idled terribly for a few minutes after installation but its all good now.
    VS Berlina
    Feb 2007
    nah its all good, The sillicone probably wasn't oxy sensor safe but it hasn't caused an issue, i'm getting 7.8 on the hwy and around 10 - 11 in town, the problem was the plenum wasn't lined up perfect and it caused a small vacume leak, runs like a dream now, better then before :P might help that I cleaned the inlet right out.
    Thanks for the help guys.
    VR
    May 2008
    how'd you clean the inlet out?
  1. Bush tension and tourqe
    By DannyboyDS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2007, 06:09 PM
  2. $150 VP/VN Auto trans and tourqe converter
    By spazworm in forum Parts And Other Items For Sale
    Last Post: 13-12-2005, 01:22 PM
  3. VP/VN Auto trans $150 and tourqe converter
    Last Post: 22-11-2005, 12:09 PM
  4. someone with a haynes manual, please...
    By pathfinderus maximus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2004, 11:09 PM
  5. Someone Forgot to drink their coffe this morning
    By The1985divo in forum Jokes/Humour
    Last Post: 30-07-2004, 01:59 PM
