Hey all.
I have a VN, I have put a VR motor in it and have stroked it, 030" oversize, Heaps of head work, port matched everything, 70mm throttle body, CAI, 3.55 LSD etc
Here are the Cam specs
Duration @ 050" is int-222, exh-232
Lobe lift - int-.317, exh-333
Valve Lift - int-.507, exh-.533
Lobe Center Separation is 113
I have just run it in and im about to get it tuned. What im asking is what injectors would go great with the setup. Im thinking V6 magna, but im not sure.
what is everyones thoughts
thanks
hey mate i'm building a similar setup tho not stroked but bigger cam and custom itnake manifold im using 28Lb GEN3 injectors theyre perfect can pik up a good 2nd hand set for less than 100buks
So GEN3 injectors will fit straight in, no hassle.
do you know what pressure there run under
thanks
