Results 1 to 8 of 8
Thread: Overheating fault
    vs S2 V6 ute 3seater
    Nov 2008
    Question Overheating fault
    Hello fello dunny door lovers,
    I have a 97 S2 V6 ute and have had a temp issue since getting it. I understand that the temp display is a uncalibrated thing and can display differently from car to car(within reason). I have resently had sometime up my sleeve and changed out the Rad, hoses, thermostate, thermostate housing & belt. I have primmed the system using the bleed screw and left it out until (car running) a steady stream of coolant was coming out. Now my grip is this, when I would go driving on a 20-30 degree day cruising i would have the gauge sittting on the third bar. When I hit traffic and/or condesgion the gauge would head to 3/4 easly. Only to slowly fall when cruising at 80-100kph. So now with the new Rad, same abent temp range. It takes a good 10-15kms to warm to th third bar but when I hit traffic again it went to 1/2 and stayed there for the rest of the trip. When I got home I ran a raytec gun over the thermostate housing and go 90-92 degees (is this to hot foe the conditions).I did break open the the tanks on the old rad to justify my purchuse of the new rad and found the water inlet side of the rad lower section had about 100mm of rust and ****, blocking the bottom section tubes solid. I am now thinking more about the fan cut in temp. Or whether because it has been stable there is nothing to worry about. What do ya think?
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    When u bled the system did u have the heater open all the way??
    I did mine and ran my heater open for 3 days and bleed it when I got to work each day short drive.
    On day 3 no air came out.
    They are a hot motor and mine runs the same as yours all normal.
    Your car is running right mate.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If there was rust and crap in the old radiator that would indicate that the correct coolant has not been used by the previous owner. The correct coolant mix plus the tablets (factory not Disprin) will ensure no corrosion. Apart from that as VS_Pete_1 says, your car is running right.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    90-92 degrees is a good range. Thermostats are genrally set to open at 96 degrees. Which is good. It's troubling if your engine gets to 120 like mine :P 130 is REALLY bad!
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    i have a slightly colder thermo in my ute, they run factory on half and if they start overheating at that temp its to hard to stop it so i dropped it 10 odd degrees and it runs on Quarter and thats a vs 304 ute
    SIR LS1
    the two ton go kart
    Nov 2008
    Sweet info, cheers guys found me overflow bottle full of **** too. not good start for the new system, would like to know more about the tablelets I do have them was not sure what they were for, Ya say they are anti corrion are how are they added?
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    The coolant is for anti-corrosion. The tablets are to plug up any microscopic holes in the aluminium parts of the engine caused by casting faults.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by fang83 View Post
    This is from the VS Owner's Handbook:
    "Coolant Specs: 50% water and 50% long life coolant conforming to Holden specification number HN 2043, part number M40236 (1 litre) or M40307 (5 litres) in addition 3 pellets, part no M40124 must be added when the coolant is replaced."
    Thats it.
  1. Overheating? Cause?
    By FullySick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2008, 06:14 PM
  2. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  3. overheating....
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-08-2006, 06:56 PM
  4. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
  5. VT overheating
    By Malcolm Logan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2005, 07:34 PM
